February 17th, 2014, 07:30 AM | #1 |
Join Date: Feb 2014 Motorcycle(s): 2008 ninja 250 Posts: 26
first ningsdays ride on cold mor
so I noticed today that on real cold mornings (30degrees) the bike stalls unless I push it to level ground..my driveway and street are both steep hills..its like the clutch hangs or something..it just bogs all the way out..ive tried popping the clutch, letting out slowly and everything in between. but once I get it going after about a undred yards or so everything is fine...I let the bike warm up for 20 mins this morning..im just wondering if the clutch or cable is worn out ( no there isn't any slipping or rough shifts its like butter) or is this just an inherent trait of the little ninja hating cold weather..
February 17th, 2014, 08:37 AM | #2 |
dirty boy
MOTM - Apr '14
i read OP 3 times and am still a bit confused what is going on?
Questions 1) Bike runs normal in say 50degree weather? 2) The bike stalls on sloped ground when just sitting there on side stand? or is this when you try to get moving? 3) So after you ride for a bit the problem stops completely? Even if you have to stop on a hill? 4) Are you using the choke? 5) Are you giving any throttle when taking off? So how you use the clutch on a cold day isn't going to matter much if you are not getting the correct amount of fuel, end result is a stall no matter if you pop clutch, or drag it out. Use full choke to get thing started and adjust lower as needed, ease clutch out, apply throttle as needed. Sounds like bike is just not warm and you are not use to getting her moving in cold conditions. 30 degrees is not that cold, a well maintained stock ninja with stock jetting should have no issues
I love the smell of burning pre-mix in the morning I don't think I'm a lot dumber than you thought that I think that I thought I was once. Last futzed with by subxero; February 17th, 2014 at 09:45 AM. |
February 17th, 2014, 09:05 AM | #3 | |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
February 17th, 2014, 09:26 AM | #4 |
Private Joker
MOTM - Mar '14
potential solution: warm the bike up longer and leave the choke on a bit + add throttle as you take off on hill starts.
I had a similar problem at one point, The bike was not warmed up enough and as a result of that the stock (lean) jetting wasn't providing enough fuel for the bike to begin moving properly with a hill start. The short term solution is just to let the bike warm up longer and leave the choke on a bit when you ride off. Long term solution rejetting. This is assuming of course that you are experiencing the same problem that I did. Subxero may also be able to provide some good advice after you answer his questions as the problem may not be the same as mine. |
February 17th, 2014, 11:07 AM | #5 |
the bike has already been rejetted by previous owner....yes I was giving it throttle when pulling off but 10 ft after moving rpms drop off even if holding throttle wide open...once I get it to flat ground it pulls off with a mild backfire sound from the exhaust and then revs pick up and bike goes just fine and from that moment on it runs like a dream even if I have to stop on a hill it pulls right off no problems..idk its weird as hell..the previous owner wasn't gentle with her...hell he didn't even clean and lube the chain for Christ sake..idk it only does this when it is stupid cold here but its my only transportation at the moment..guess I will figure it out or live with it...
February 17th, 2014, 11:08 AM | #6 |
lol johnnybravo
March 21st, 2014, 06:05 PM | #7 |
hate to restart a dead thread but I figured out the problem..it was partly due to the cold and partly due to the awful adjustment the previous owner had done to the poor bike but all fixed now and she runs like a dream
March 21st, 2014, 06:58 PM | #8 | |
What did you do? Re-jet? You should have if you still got #110's in at your elevation. You may be too rich depending on your intake and exhaust set up. |
March 21st, 2014, 08:02 PM | #9 |
Blind 250 Loving Whore
You still didn't really answer what you do with the choke when you ride off. Are you leaving the choke full on then letting the bike warm up and riding off with the choke on?
You say the previous owner didn't even lube or clean the chain but you believe that he actually jetted the bike? Have you checked? |
March 21st, 2014, 09:38 PM | #10 |
he had the idle air misadjusted and the clutch cable was out of adjustment lightly..i now start the bike full choke and let it warm up 5-10 minutes slowly backing choke off..one the idle is at 1200 im able to to ride off no problems at all..ive also removed the carbs and gave them a good cleaning, did an oil change on it, it had about 1qt of oil in it and the filter wa put together incorrectly so Ive caught the bike up on maint. so now she purrs..
March 22nd, 2014, 06:53 AM | #11 | |
Which filter, air or oil? Do you have an airbox or pods? Did you correct the jetting? What do your spark plugs and exhaust end cap look like? |
March 22nd, 2014, 08:01 AM | #12 | |
If engine is still weak to pull up on the hill is because it is being fed with less fuel than what it needs (the air-fuel mix is lean). In that situation, full opening the throttle makes things worse (too much cold air and not enough fuel) killing the internal flames; just give it more fuel via more choke. The choke in these bikes is named incorrectly as it is not choking anything; it is simply an additional injection of fuel into the intake passage in order to compensate the naturally lean mix produced by a cold carburetor and a cold engine (some of the fuel droplets condense on the cold surfaces before reaching the combustion chamber). Lubrication of the cylinders in those cold-choke applied conditions of start up is marginal; hence, you put more wear on your engine's rings by letting it warm up at low rpms (idle). Please, read this: http://faq.ninja250.org/wiki/What_is..._at_startup%3F
March 22nd, 2014, 08:45 AM | #13 | ||
He says it runs like a dream and the clutch shifts like butter with about a QT of oil. IDK. I willing to bet with a little fine tuning the bike will run even better overall. |
March 22nd, 2014, 05:07 PM | #14 |
its a dynojet kit...and I have recently installed a slipon on the bike to replace the old muffler the previous owner had a stock gsxr muffler on it that he cut off some other bike..ive also got k&n pods the previous owner had already removed the stock airbox...the bike runs very well lol I know you guys don't believe me but it does I warm the bike up for a minute or 2 and im able to ride off even on a hill now..i was just wanting to give an update lol...and when I did the oil change it only had 1qt in it I filled it to factory spec now so with all the crap the previous owner did wrong to thi poor bike its no wonder it ran awful but since I have corrected all this it runs like a dream and I couldn't ask for a better bike to be on.
March 23rd, 2014, 08:11 AM | #15 |
Never too cold to ride | CC Cowboy | Ride Reports | 42 | April 16th, 2014 06:15 AM |
5trstt3dygxrgctbrģ cold tires on a cold day | thomason2wheels | !%@*#$%!)@#&!%@ I crashed! | 6 | December 1st, 2012 08:34 AM |
[topix.net] - Giving warms bikers on a cold, rainy ride | Ninjette Newsbot | Motorcycling News | 0 | November 27th, 2011 08:10 PM |
[roadracingworld.com] - AMA SuperSport Field Closes In On Mercado During Saturday Mor | Ninjette Newsbot | Motorcycling News | 0 | May 16th, 2009 10:10 AM |
[roadracingworld.com] - Stoner Out In Front During First MotoGP Practice Thursday Mor | Ninjette Newsbot | Motorcycling News | 0 | June 26th, 2008 06:41 PM |
