February 18th, 2014, 04:47 PM | #1 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
Recommend me a Carb Rebuild Kit
Seems my carbs were leaking a little so I'll go ahead and rebuild them while the engine is out.
I'm running aftermarket jets/needles so what else do I need besides the o-rings?
Mods: Offset clutch pressure plate |
February 19th, 2014, 07:10 AM | #2 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
I see the K&L supply rebuild kit more then any other for the Ninja 250.
http://www.powersportsuperstore.com/...tm?Click=35177 I know with my carbs the floats needles and seals were bad so replacing those fixed the leak. My petcock was also bad which contributed to the leak so I replaced that as well but you can get a rebuild kit for a bit cheaper. Last futzed with by agentbad; February 19th, 2014 at 06:18 PM. |
January 19th, 2015, 05:14 PM | #3 |
Just to confirm you need two of these right? I just want the damn o-rings for the bowls!
January 19th, 2015, 06:51 PM | #4 |
January 20th, 2015, 10:09 AM | #5 |
Lostcause enthusiast
Join Date: Jan 2015 Motorcycle(s): 2000 EX250F Posts: 178
5 bucks, not bad.
be sure to check your float height while you have them apart, a lot of the time just doing that will fix a lot of leaks and weirdness. |
January 20th, 2015, 10:27 AM | #6 |
Ordered! Now hopefully I can cancel the other sites order....
January 20th, 2015, 06:13 PM | #7 |
I've used http://www.murphskits.com/product_in...roducts_id=464 in the past.
I usually get the stuff 2-3 days.
January 20th, 2015, 07:35 PM | #8 |
How about a petcock rebuild kit since that's what I really need lol
January 21st, 2015, 10:10 AM | #9 |
I just spent the extra 30 bucks and got a new oem tap.
08+ Carb Rebuild Kit | EternalNewb | Items Wanted | 3 | April 8th, 2015 11:06 PM |
Carb rebuild kits for EX250 | Linkin | 2008 - 2012 Ninja 250R Tech Talk | 1 | March 18th, 2015 04:05 PM |
Can't find carb rebuild kit? | redeiko0713 | 2008 - 2012 Ninja 250R Tech Talk | 17 | September 28th, 2013 09:32 PM |
carb rebuild help | deanomyte | 1986 - 2007 Ninja 250R Tech Talk | 12 | November 18th, 2012 07:29 PM |
