April 9th, 2009, 11:06 AM | #1 |
NinjaBunny
Gas Tank Replacement
Hello all,
I have a 2001 Ninja with a hole in the gas tank due to rusting. I'm planning on replacing the gas tank and wanted to know where I should look for the new bolts and washers. The gas leak ate away at the ones that were on there. |
April 9th, 2009, 11:11 AM | #2 |
Hey Liz.
Try here: http://fiche.ronayers.com/Index.cfm/.../Fuel_Tank(1/4) I'm sure others will chime in later.
my flickr™ |
April 9th, 2009, 11:14 AM | #3 |
April 9th, 2009, 01:48 PM | #4 |
Liz,
the hole can be repaired with JB weld instead of buying a new tank. I bet the hole was due to using the wrong length screws that hold the fairings on? |
April 9th, 2009, 10:49 PM | #5 |
Join Date: Feb 2009 Motorcycle(s): '91 Honda CBR600 F2 Posts: A lot.
C'mon Kim! You're the one always telling us to read!
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail. |
April 9th, 2009, 10:55 PM | #6 | |
I read... perhaps I'm reading too much into her post. a lot will cleared up a lot when she responds. |
April 9th, 2009, 11:05 PM | #7 |
Very true. It is possible that what you're thinking is the case, but my initial impression was that gas leaked out of whatever hole and ended up all over the bolts etc. We shall see!
Gas Tank Lock stuck? Maintenance for gas cap with pics! | Skippii | 1986 - 2007 Ninja 250R Tech Talk | 35 | May 6th, 2021 09:03 PM |
DIY: Super-Secure Gas Tank Holder (for when your tank is removed) | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 21 | June 16th, 2014 01:20 AM |
Replacement gas tank only has one hole on the side? | IF13 | 2008 - 2012 Ninja 250R Tech Talk | 10 | September 20th, 2013 11:17 AM |
Replacement Gas Cap | Clayton-007 | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 10th, 2012 09:58 PM |
