March 9th, 2014, 11:17 AM | #1 |
Join Date: Apr 2011 Motorcycle(s): 2008 Ninja 250r, Fazer8 Posts: 580
Think twice before installing an extra horn
Imagine you want an extra horn on your bike, just for the heck of it...
Here's a hint: Don't install it in front of your radiator!!! The nut which holds the horn to the metal bracket slammed repeatedly into the radiator, now I have a leak... (it also hit my front fender) It doesn't seem to be a problem when the bike is cold, but when the temperature goes up, sometimes I get a small cloud of clear smoke into my face for about 5 seconds. (That really happens very rarely, almost never, only when running hot) I guess I can continue riding as I mostly do highway where the engine stays cool thanks to aircooling. Although the needle rises quickly when doing jammed city traffic, it never gets to the redline... suggestions?
I can not be a true player by playing around. |
March 9th, 2014, 11:37 AM | #2 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
Drain the system and pull the radiator, use some needle nose pliers and clear the area just a tiny bit so you can clean it and solder the pinhole.
One time in my mustang the clutch fan bearing decided to crap out and left a smiley in a brand new aluminum radiator. I feel your pain. |
March 9th, 2014, 11:51 AM | #3 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Bummer. Hope you can fix your radiator per above.
Thank you for the warning! |
March 9th, 2014, 11:57 AM | #4 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar Posts: A lot.
Yikes. Thanks for the warning. My family has asked me to install a bigger horn a couple of times, so I'll keep this in mind if I ever do.
March 9th, 2014, 12:11 PM | #5 |
i have fixed several radiators. depending on how bad the hole is there are a few different ways to fix it. if it's a small pinhole in the very front or back of one of the tubes (caused by a bolt or something) you can solder, i prefer to use high strength high temp chem resist epoxy (drain the system first, let it dry before filling again) because you can really cram it in there with your finger and it doesn't have the same kind of porosity issues welding and soldering can have. if you are on the side of the road, the melting point of most plastic is between 350 to 450f so you can melt a ziptie with a lighter and jam it in the leak hole then melt the rest of it off. then just pee in the radiator to fill it back up after the leak. since your cooling system should not get above 100c it never has a chance to get as high as 200c to melt that plastic.
if the radiator tube is bent and cracked in the middle of the tube (between the fins), you have to carefully remove around it (don't pull the fins or they will tear more holes, you have to carefully cut them) and either remove the tubes that are too far gone and plug both ends, or just replace the thing
March 9th, 2014, 12:14 PM | #6 |
Ninjette Jockey
Join Date: Oct 2010 Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP Posts: A lot.
A pinhole on the road can also be slowed down with a screw. This radiator is aluminum, you are not going to solder that, but like alex.s said, there are special expoxies. You may need to find a good used radiator, and not risk having it start leaking far from home.
The horn can be mounted on the side, under the fairing and still be quite loud. Also, it will not clog up with bugs there. If you add an air horn, remember that you need to add a relay.
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?. |
March 9th, 2014, 01:00 PM | #7 | |
Your radiator cannot develop the designed pressure and you are losing coolant more or less quickly, even if you don't see leaks or steam. The cooling system in our bikes is marginal and easily under-performs if things are not as they should. You are risking overheating and low level of coolant around the heads and cylinders, and that will create a chain reaction and expensive repairs. It is very easy to inadvertently cross the fine line that separates the current condition from a blown head gasket or more damage. This is how the cooling system works: http://faq.ninja250.org/wiki/Cooling_system
March 9th, 2014, 01:18 PM | #8 |
Que Buenos Son!!!
MOTM - Nov '14
Crack an egg into it. It worked on Mythbusters
March 14th, 2014, 01:12 AM | #9 |
Join Date: Mar 2012 Motorcycle(s): Black 2012 Ninja 250R Posts: 93
I put an "aftermarket" car horn in replacement of the stock one. Wasn't much bigger or heavier, so far now problems. I better check though now, in case it is causing damage.
But now I got this beast mounted in the back. It gets your attention. |
Thank you Horn! | nvxdiz | Ride Reports | 11 | October 20th, 2012 12:19 PM |
Horn Not Working | Liist | 2008 - 2012 Ninja 250R Tech Talk | 2 | October 30th, 2011 11:01 AM |
Installed Stebel Nautilus air horn, a.k.a. Wolo "Bad Boy" horn | FrugalNinja250 | 1986 - 2007 Ninja 250R Farkles | 8 | June 23rd, 2011 05:37 AM |
DIY Installing Wolo Badboy / Stebel Nautilus Horn | kevlarorc | 2008 - 2012 Ninja 250R Farkles | 7 | November 9th, 2010 06:21 AM |
no horn | Ntotot | 2008 - 2012 Ninja 250R Tech Talk | 10 | September 28th, 2009 07:04 AM |
