June 12th, 2014, 06:00 AM | #1 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Should I do the valve clearance inspection myself?
Option one : Pay someone...
Option two : do it myself and possibly mess up really badly
June 12th, 2014, 06:06 AM | #2 |
Do it. At least take it apart and measure the clearances and write them down. If you find some of them need adjustment and aren't confident in removing cams, etc, consider taking it to someone to do. Bring your list of which feelers fit and which ones didn't (go and no go feelers) for each cam so they know which ones need attention and can double check your work.
Do you have any family friends with experience wrenching on engines? |
June 12th, 2014, 06:09 AM | #3 | |
#squid
MOTM - Jul '16
My dad does, but, his skills are...I don't want to do it with him. lol
June 12th, 2014, 07:32 AM | #4 | |
Nerd
Join Date: Mar 2012 Motorcycle(s): Ducati Hyperstrada Posts: 672
Check-Only should be pretty simple. Just read up on it
It doesn't LOOK that steep. But you can go first... |
June 12th, 2014, 08:08 AM | #6 |
#squid
MOTM - Jul '16
14.2 K uncorrected I think ...I don't have a speedo healer.
June 12th, 2014, 01:27 PM | #7 |
#squid
MOTM - Jul '16
Could you guys recommend a good feeler gauge? Not sure if a crappy autozone or harbor freight gauge would pass.
For the Valve Cover Gasket I have ultra black rtv...is that okay? I think that's all I need besides the actual shims, which I hope I don't need. After reading the service manual, it actually doesn't seem that complicated, gonna watch some videos though. Any tips?
June 12th, 2014, 04:46 PM | #9 |
#squid
MOTM - Jul '16
just want to make sure the measurements of them are spot on...
June 12th, 2014, 05:14 PM | #10 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
June 12th, 2014, 06:13 PM | #11 |
#squid
MOTM - Jul '16
Where'd you buy it?
June 12th, 2014, 06:22 PM | #12 |
Participant
I bought mine at a local Tool Town: they sell decent-quality asian tools at a fair (but not cheap) price. I'll bet Harbor Freight would have them, too.
Being an old guy, I think in inches, so all my feeler gauges are in thousandths of inches. Dunno if metric go/no-go feeler gauges are common. Remember, 1 mm = 0.0394 inches. |
June 12th, 2014, 06:24 PM | #13 | |
#squid
MOTM - Jul '16
June 13th, 2014, 12:50 AM | #14 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
TL;DR I'm a cheap mechanic and my bike was really broke but I managed to do it.
I did the whole adjustment myself on my CBR, it was a bit scary and took like 5 days all said and done but I wasn't in any hurry and just took my time, could easily do one in a day now provided I had everything I needed for it. I plan on doing a check, and probably not needing to adjust on my 919 in 5k miles when it's time for it. My clearances were so tight that I had literally no clearance on 2 valves and very little on the rest, only on the intake valves. All 8 exhaust valves were at some degree of within spec. so I had to make a guess with shim size and my guess wasn't good enough so I had to readjust those two valves which meant taking out the cams again, going to the shop again to get more shims, readjusting, retiming, etc basically a two for one deal on adjusting my valves which isn't a good deal lol. My first time timing it I used the wrong mark on the flywheel so I had PTV contact which is why you ALWAYS turn slowly by hand first because that would have otherwise destroyed my engine. Then after my final readjustment my torque wrench never clicked when torqueing the cams down so I snapped a bolt in the cam holder plate, luckily enough was still connected the whole thing came out and I replaced it with a bolt of the same grade as OEM from a local fastener store which luckily seemed to work as well as OEM too haha. FINALLY I had all the valves in spec and I had to dick around with the stupid manual CCT the bike had, which I had to JB weld the adjustment bolt onto it because the pin that held it on broke, blah blah set chain tension put throttle bodies back on get new battery FINALLY START THE BIKE VROOOOOMMMMM she started right up, better than she ever had before. Actually, the intake valves were so tight the bike wouldn't even start anymore towards the end from lack of compression. Only put a bit over 2k miles on it after that but that included a cross state trip, a track day where it whooped a lot of faster bikes on the straights, twisties, lots of sitting in traffic at 225 degrees burning the heck out of me (thank God the 919 isn't like that) temperatures ranging from 28 degrees to 105 degrees, and lots of pathetic attempts at first and second gear clutch ups. Now the new owner loves it and apparently races his friends on bigger bikes all the time and easily keeps up.... Moral of the story is if I can do it on my first time with crappy tools and no organization on a bike in a serious state of disrepair, I think you're golden. |
valve inspection | jcsalazar | 2008 - 2012 Ninja 250R Tech Talk | 2 | October 18th, 2014 04:37 PM |
valve clearance | sharky nrk | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 18th, 2014 06:19 AM |
Did I just grenade my motor by going 1k over on the valve inspection? | bowlingballhead | 2008 - 2012 Ninja 250R Tech Talk | 21 | July 11th, 2013 08:17 AM |
Valve Clearance Problem | ElJokerr | 1986 - 2007 Ninja 250R Tech Talk | 9 | February 22nd, 2013 12:40 PM |
valve clearance??? what are they supposed... | ecannon1 | 1986 - 2007 Ninja 250R Tech Talk | 3 | May 20th, 2010 10:41 AM |
