September 1st, 2014, 05:32 PM | #1 |
blinkers work sometimes
Lately i have been havingt this problem. Sometimes the blinkers work,a nd sometimes not. I checked the relay and it looks fine.. As far as i can tell.
On a ride, it might not work for 20 miles, then the next it will work. I thought it might have been the vibration causing the relay or something to malfunction. Anyone know what might be the cause. |
September 1st, 2014, 05:34 PM | #2 |
sammich maker
MOTM - Apr '15
Check the connection, sounds like they are either loose or you have a bad wire or ground.
September 2nd, 2014, 02:24 AM | #3 |
Down Under
Join Date: Jun 2014 Motorcycle(s): Kawasaki ZXR250C Ninja Posts: 296
Is it just one side at all? Or both?
In any case, take all four apart and check the contacts/wiring |
September 2nd, 2014, 06:07 AM | #4 |
dirty boy
MOTM - Apr '14
stock signals and relay?
September 2nd, 2014, 06:25 AM | #5 |
it is stock signals and stock relay. If the signals go out, they go out for all of them. Even the blinking signals in the dash disappears.
September 2nd, 2014, 09:04 AM | #6 |
sammich maker
MOTM - Apr '15
I am thinking ground wire, could be a bad switch too.
September 2nd, 2014, 12:17 PM | #7 |
dirty boy
MOTM - Apr '14
is this your bike with like 80k miles on it? I would try just replacing the blinker relay to start with before I started checking all the wiring.
September 2nd, 2014, 07:27 PM | #8 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
change the bulb?
cheap, and quick. flick the bulb and see if the filament is loose |
September 3rd, 2014, 04:15 AM | #9 |
The bulbs are good, its a weird wiring problem.
But can't find it, i looked at all the wires and they appear good. But i need to take a bit more time to look through it. |
New Blinkers | kennetht | 2008 - 2012 Ninja 250R Tech Talk | 24 | February 1st, 2014 12:14 PM |
Electric start problem, lights, blinkers, and indicator lights work. | claymaker | 1986 - 2007 Ninja 250R Tech Talk | 8 | July 10th, 2012 07:04 PM |
Blinkers won't work? PLEASE HELP | Snowman78666 | General Motorcycling Discussion | 2 | November 9th, 2011 04:04 PM |
blinkers don't work | Domagoj | 2008 - 2012 Ninja 250R Tech Talk | 11 | January 8th, 2011 12:03 AM |
making an integrated tailight and flush blinkers work...I searched | Mac | 2008 - 2012 Ninja 250R Farkles | 2 | August 30th, 2010 04:29 PM |
