May 27th, 2009, 05:18 PM | #1 |
Join Date: May 2009 Motorcycle(s): 09 250r. 02 cbr f4i Posts: 24
upshifting noise, need some help.
I was out for a ride with my visor up and noticed a new noise i'm not use to hearing. While I'm shifting through the gears, i'm hearing a noise sorta like a goose, bruuuummmp, everytime i upshift. As far as I can tell it doesnt do it in 5th and 6th but I couldn't be sure because by that time there is so much wind and engine noise it would be drowned out.
Any ideas before I start tearing her down would be much appreciated. |
May 27th, 2009, 05:21 PM | #2 |
is it shifting cleanly into the next gear? could it be a misadjusted shift pedal and you're not lifting it high enough into the next gear?
does it make the same noise when downshifting? miles on bike and the last time the oil was changed? |
May 27th, 2009, 05:23 PM | #3 |
are you sure the clutch cable is properly adjusted? oh, you might want to get alex to put the f in the title for you
May 27th, 2009, 05:24 PM | #4 |
FORMER MOTORCYCLE RIDER
Join Date: Dec 2008 Motorcycle(s): Rode an 08 250r then rode an 08 ZX-6R until i totaled it on 7/10/10 Posts: 758
I was guessing the "Gas Cap Vent"
May 27th, 2009, 05:26 PM | #5 |
May 27th, 2009, 05:31 PM | #6 |
haha sorry guys, was in a hurry. 1900 miles, oil changed at 700 miles. Uhm, no noise while down shifting, just up. shifts clean, no lag in power or anything. I'll check the clutch cable tonight. At work right now shhhh
May 27th, 2009, 05:42 PM | #7 |
If it continues after the checks, why not just take it back to the dealer and let them fix it?
May 27th, 2009, 05:51 PM | #8 |
Because I believe they will charge half hour labor... Thanks though
May 27th, 2009, 06:19 PM | #9 |
Join Date: Apr 2009 Motorcycle(s): 2009 ninja 250r Posts: 46
warranty?
May 27th, 2009, 06:28 PM | #10 |
All set.
May 27th, 2009, 07:27 PM | #11 |
May 27th, 2009, 07:35 PM | #12 |
if within warranty term then dealer shouldn't chage to take bike for a ride and evaluate. worse thing should be the old "unable to reproduce problem". but shouldn't cost you any diagnostic charge.
May 28th, 2009, 06:16 PM | #13 |
any luck?
May 28th, 2009, 09:01 PM | #14 |
No luck with the clutch cable, wishing right about now I was more mechanically inclined, but I did notice the shift lever was a tad loose just didn't have the right tool to tighten it. When I get that tightened if it still makes the noise I guess I'll take it in. I might have voided warrenty considering the bike has been dropped. Anyways thanks everyone for your help!
May 28th, 2009, 09:10 PM | #15 |
Even when the bolt that holds the shifter lever on is properly tightened, you will still see the shifter move. That's how it's able to shift. I think the tools in the kit that came with your bike includes wrenches that should fit that bolt.
Just make sure you don't overtighten that bolt when you check it. I just read in another post it should be something like (IIRC) 105in/lbs... which is like 8 ft/lbs. dropping the bike should not void your warranty, unless damage from the drop is directly responsible for the noise you are hearing. |
May 28th, 2009, 09:56 PM | #16 |
Join Date: May 2009 Motorcycle(s): 2008 Kawasaki Ninja 250R, 2009 KTM 690 SMC, 2001 Suzuki GSX-R 750 (track bike) Posts: 172
Going out on a limb, but are your rpm's high enough when you are shifting? Too low, and the engaging dogs won't slide into each other smoothly. Just a thought.
Upshifting sticks | ryan.chin | 2008 - 2012 Ninja 250R Tech Talk | 18 | August 12th, 2012 08:14 PM |
Upshifting Speeds question | dcx4610 | Riding Skills | 13 | July 22nd, 2012 04:47 PM |
Upshifting - clutch or clutchless? | ally99 | Riding Skills | 151 | June 16th, 2012 08:04 PM |
Upshifting... | supermanzdead | Riding Skills | 3 | October 30th, 2010 06:25 PM |
'06 noise while upshifting | Navyboy | 1986 - 2007 Ninja 250R Tech Talk | 10 | October 23rd, 2010 02:26 PM |
