#1 |
05 Ninja decal removal
I have read at other places around the internet that it is possible to remove the flame decal on the pregen ninjas that have it. I am wondering if it is possible to remove the decal that other pregen ninjas have on them. I.E. is it under the clearcoat, or is it just a sticker? Here is an example of what I am talking about:
![]() Would it be possible to remove the silver and green from this bike? I have a feeling that if you can remove any of it, you will not be able to remove the part on the gas tank, and I assume the whole lower fairing is silver... |
#2 |
i'm a cow killer
you can remove all of it.
it will be a beotch to get off have fun |
#3 |
MOTM - Sep '18, Feb '16
I think all the stickers come but the gas tank stripe. That is a vinyl decal with clear paint over it . I had to repaint a 2003 ninja and thought I could just sand off the clear and paint over it. I had to strip the whole tank to get the stripe off. the rest come off with a heat gun and some care.
#4 |
Livin' the Minimoto Life
Join Date: Mar 2009 Motorcycle(s): 2022 Honda Navi, 2018 Z-125 Pro Posts: A lot.
Heat gun + dental floss = decal removal
Ok, I've used it to remove the adhesive badges on cars. Normal decals should just peel off once you get them hot enough. Watch it with getting too hot, bubbling paint/plastics isn't good. ![]()
--- My IG Page --- My FB page! --- 2022 Honda Navi && 2018 Z-125 Pro |
#5 |
Join Date: May 2009 Motorcycle(s): 2005 ninja 250 Posts: 23
i have the same bike! i think the scheme looks sexy! but i heard a hair dryer and goo gone works.
#6 |
Join Date: Feb 2009 Motorcycle(s): '91 Honda CBR600 F2 Posts: A lot.
I'm slightly confused here... Did you want all the silver gone? Correct me if I'm wrong, but I think the lower half of your fairing is actually painted silver. Are you just repainting that or buying a black one or was that not part of your question? From what I've seen for the regular decals (I.E. the flames on the later models) they're just like stickers and peel off fairly easily. Of course, I'm a total tech noob, so I'm probably wrong about that.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail. |
#7 |
Join Date: May 2009 Motorcycle(s): 2004 ninja250r Posts: 17
soo what i did was run really hot water over my vinyl stickers and this made them come off fairly easy, I ended up sanding my whole tank down into the base then repainted.
there is no gain without risk |
#8 |
North Alabama Mtn. ryder
ha ha dont be like me and buy acetone and drink beer while sweating away removing the decals and road tar
#9 |
Ryan,
You do realize that removing the green from a black bike is going to result in a slower bike, don't you? ![]() |
#10 |
just put on some K&N stickers those will give you and easy 5 horse power each!
#11 |
then paint it red to outrun busa's
QTRltrPWR |
Ninja Decal Measurement!!! Please Help. | bad_bwoy007 | General Motorcycling Discussion | 4 | April 30th, 2012 11:22 AM |
Airbox removal + Kleen air removal? | MikeBudd | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 16th, 2012 04:57 PM |
need some quick help - decal removal | Rys | General Motorcycling Discussion | 1 | September 28th, 2011 07:33 AM |
decal removal | egb1108 | 2008 - 2012 Ninja 250R Farkles | 7 | June 12th, 2011 06:47 AM |
ninja decal | ninjablk08 | 2008 - 2012 Ninja 250R Farkles | 10 | June 12th, 2009 10:10 PM |
