February 16th, 2015, 02:38 PM | #1 |
Join Date: Sep 2014 Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4 Posts: 250
Where do you get your screw needs?
due to my attempt to mod my ninja 250, I am in need of grade 8 M12 in 120mm length with the finer the pitch the better.
It appears they are hard to find even on line from my recent search. I ,after a wasted trip to a small store ( in the Miami Area) where the guys told me he had the M12 grade 8 only for it to be grade 8.8, am wondering what you guys do to satisfy your strong bolt needs? Mitch's Welding has usually had what I need but he does not carry grade 8 nor 10.9 (also Miami) Miami Welding | Miami Welders | MitchellsMiami.com | Miami Welding Machine Fasters gonna try later this week (also Miami area) this place below in Medley (gosh I hate the traffic) where I might find what I am looking for but can not be certain until the goose is cooked. Contact Us - General Sales Fasteners i tried a couple online but the 120mm M12 appears to be a rare diamond for my search abilities. This is for those of you in the Miami Area for local stores or for you'all then online sources |
February 16th, 2015, 02:44 PM | #2 |
Join Date: Feb 2015 Motorcycle(s): 286, 296, 599, 799 Posts: 436
there is no grade 8 in metric. It's 8.8 (gr 5), 10.8 (gr 8) 12.8 (gr 9) the relationship to SAE grade isn an "ish" measurement. It's not an exact 1 for 1 swap.
in 12mm you can have 1.75 thread in a 10.8 or 1.25 thread in an 8.8 both are available from McMaster.com http://www.mcmaster.com/#standard-cap-screws/=vxsxhy |
February 16th, 2015, 03:30 PM | #3 |
wife...
My replies are intended for street riding only, plz do not provide track only replies. Visit my new MotoVlog Channel !! |
February 16th, 2015, 03:45 PM | #4 | |
stock bolts grade? pre gen and new gen ninja 250 shock linkage
i'll go with the 10.8 minimum,, to be safe as I can not tell what grade the stock ones are, can you? its for making my rear shock linkage wider to fit a wider spring from an 05/06 GXSR 1000 |
February 16th, 2015, 03:54 PM | #5 |
http://en.wikipedia.org/wiki/ASTM_F568M
those appear to be non standard markings. It may be something Kawi did so the people on the line knew. Bolt #7, #8, #9 goes in which holes. With no obvious marking, and being used in double shear. I'd go with a commonly available 8.8 I also made a mistake in the above post. SAE gr8 is about equal to Metric 10.9 edit; something more important than the bolt grade you need to consider. Find a bolt long enough that all of the loads will be on the shoulder not the threads. That will increase the strength even more. If you need a 200mm bolt to achieve this just cut the end off after you put the nut on. |
February 16th, 2015, 05:03 PM | #6 | |
but even with a screw with a bolt head side with a shoulder, on the other end where the nut goes, that side dogbone would still be resting on threads... so not sure how to avoid having dogbones not rest on threads but what you say makes sense. |
February 16th, 2015, 05:11 PM | #7 |
a thread in the end of the nut side leg isnt a deal breaker. In an ideal world all the load would be on the shoulder and you'd have a washer to space the nut to the threads.
February 16th, 2015, 05:45 PM | #8 | |
Take a look at this: http://forums.ninja250.org/viewtopic.php?p=853294 It is important to fit as much of the cylindrical neck (rather than the threaded section) into the holes in the chassis as possible.
February 16th, 2015, 05:55 PM | #9 | |
February 16th, 2015, 06:04 PM | #10 | |
February 17th, 2015, 10:15 AM | #11 |
Join Date: Jan 2014 Motorcycle(s): 1996 Ducati 900SS/SP 45k miles Posts: 132
needs. . .
I go to my local Superior Industrial Supply on Vulcan Street in St. Louis MO.
Great service, wide selection, both fine threads and 10.9 grade bolts & nuts. Fred
'09 Ninja 250R track only SOLD "If everything seems under control, you're not going fast enough." -Mario Andretti |
February 17th, 2015, 11:58 PM | #12 |
Join Date: Apr 2012 Motorcycle(s): 09 Ninja 250R, 98 RS150R Posts: 31
In California McFadden Dale has a great selection!
February 22nd, 2015, 11:47 PM | #13 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
The backseat of a Cadillac
February 23rd, 2015, 05:36 AM | #14 |
February 23rd, 2015, 07:53 AM | #15 |
Lostcause enthusiast
Join Date: Jan 2015 Motorcycle(s): 2000 EX250F Posts: 178
fastenal is pretty good, usually gets to me in 2-3 days and you can buy bolts by the each.
i always try to buy this stuff local, but lately the hardware stores just stock a bunch of china junk, if they stock anything at all... lowes and home cheapo are worthless. if you can find an old school hardware store, you're lucky. |
February 23rd, 2015, 08:45 AM | #16 | |
and really happy with them and their web page is full of info and the sales people are useful and friendly. |
2008+ Ninja 250 Carburetor Screw size, allen screw size! | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 2nd, 2015 11:49 AM |
A Screw | GearMonkey | Items Wanted | 8 | May 7th, 2013 04:50 PM |
Where does this screw go? | PistolPete93 | 2008 - 2012 Ninja 250R Tech Talk | 24 | March 5th, 2013 09:29 PM |
Theres a screw -__- | A Tomato | 2008 - 2012 Ninja 250R Tech Talk | 20 | July 7th, 2012 11:01 PM |
Where does this screw go? | patw | 2008 - 2012 Ninja 250R Tech Talk | 28 | January 7th, 2012 09:15 AM |
