Old April 16th, 2015, 11:16 AM   #1
bigbadbob
Motorcycle(s): Bandit 750, Trike.
ecotrons tech questions.
Hi guys. I'm a newbie here and althoough i don't have a ninjette i'm interested in how you guys use the ecotrons kit, you have a wealth of info about it on here and obviously plenty of experiance with it so this seems like the best place to ask questions.
I have a couple of tech questions i'd like to ask if that's ok.
First off... looking at the ninjette wiring diagram it has one ignition pickup so looks like the ignition is a wasted spark system, is this correct?
and if it is wasted spark is the ecotrons a wasted spurt setup?
ok, maybe wasted spurt is the wrong expression as the spurt is not wasted but the analogy is similar.
I guess what i'm really asking is- does each injector spurt twice per cycle (once per rev)?
finally.... what is static timing of the ignition pickup?
I understand the ignition varies between 10* BTDC and 35* BTDC dynamic but i need to know angle between pickup and TDC.
BBB.
bigbadbob is offline   Reply With Quote
Old April 17th, 2015, 10:50 AM   #2
bigbadbob
Ok. here's another queston.
can anyone tell me their values for-
VAL_dlgaGap2TdcAdj
VAL_dlnjAngGap2TdcAdj
VAL_vEng
VAL_nRevPerCycle
and whether ProCAL will let you set a multi tooth trigger in
"calibrations>sensor Characteristics>Crank Position Sensor"?
Tech Questions 08ninja250 2008 - 2012 Ninja 250R Tech Talk 6 February 25th, 2011 08:41 PM
New Here, Have some Tech Questions btovar250r 2008 - 2012 Ninja 250R Tech Talk 6 February 12th, 2011 10:54 AM
[topix.net] - Motorcycle Tech Questions and Answers Ninjette Newsbot Motorcycling News 0 September 3rd, 2010 05:40 PM
[topix.net] - Tech Questions & Answers Ninjette Newsbot Motorcycling News 0 August 13th, 2010 10:30 PM
[sportrider - tech] - Ask the Geek: Michelin Tire and Master Cylinder Questions Ninjette Newsbot Motorcycling News 0 July 7th, 2010 05:50 PM
