July 5th, 2015, 10:02 PM | #1 |
Join Date: Nov 2011 Motorcycle(s): Many Two Wheels .. Posts: 611
08-12 Ninja 250 fork spring -- 0.8kg.
Worth a shot, but wondering if anyone has one.
[ex-AFM #828 | SMUSA #828 | Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers + OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com |
July 5th, 2015, 10:53 PM | #2 |
Why not just cut and shim the OEM spring?
July 6th, 2015, 06:52 AM | #3 |
Track Clown
MOTM - Sep '15
Full gear i am ~205-210 at the track, I have 0.8 and feel that i could go softer, i am not getting enough weight transfer to the front under braking/deceleration.
July 6th, 2015, 07:11 AM | #4 |
Freedom for Germany
@cbinker I absolute support what you're saying.
Note: "The correct spring is the softest spring available, that is able to support the bike and rider under the hardest of braking/accelerating while still leaving some room for the system to travel if a bumb is encountered in this state." Read all about it here: http://www.peterverdone.com/archive/springs.htm And by the way from what I think the idea from @Ghostt is a very good way to go (since it's expensive to buy all springs in different weights). So just cut the oem springs in different stages and test until you find the best solution for yourself. Nobody can trust/rely on any magic number given anywhere, it all has to be well tested by everybody itself. |
July 6th, 2015, 07:57 AM | #5 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
I have .8 springs. They were a little too soft for me so I ordered .85s. The springs are the same length so you'll get the pvc, washers, and springs with instructions. The whole kit!
July 6th, 2015, 08:03 AM | #6 |
Track Clown
MOTM - Sep '15
I also did emulators.
something else I am looking at doing is shimming the rear-end up a bit. |
NewGen Fork Spring Rate Chart | InvisiBill | 2008 - 2012 Ninja 250R Tech Talk | 6 | May 30th, 2015 08:16 AM |
Fork Spring Question | Dsheumaker | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 25th, 2015 05:08 PM |
Anyone know the stock fork spring rate? | Rizod | 2008 - 2012 Ninja 250R Tech Talk | 8 | April 10th, 2012 05:42 PM |
fork spring upgrade | upon1#19 | 2008 - 2012 Ninja 250R Tech Talk | 16 | May 13th, 2011 07:20 PM |
