July 25th, 2015, 09:30 AM | #1 |
Join Date: Nov 2013 Motorcycle(s): R6, Kawi 250 Posts: 86
250/300 engine tips/advice?
So I did a bunch of searches and I know at least a couple people have put a 300 motor into a 250 (2009). The threads I read though we're a little light on details. Can any share a more in depth how to on removing the old engine and putting the new 300 motor in? I have a complete 300 sitting right next to my 250 so I should all the required parts for a full 300 if swap
July 25th, 2015, 09:53 AM | #2 | |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
Pretty much just take out the whole engine, wiring, ecu and replace it with the 300 stuff. Mounts are the same. I put the engine in first. Then proceeded with the 300 wiring. This will take the most time since you need to figure out how the wiring will go, zip tieing, etc. And finding a spot for the ecu to sit. You might have to cut the lower newgen fairing to fit the header. Also source out a fuel pump and splice that in. I got mine from ecotrons.com for 30 bucks and works perfectly. Its a straight swap just you need to wire it up and that can take time. PM me if you need any more specific details.
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
July 25th, 2015, 09:55 AM | #3 |
Also I made the 300 gauge cluster fit on my pregen. I would do the same in your case since it would be a big pain to re-pin the newgen cluster to get all the same data from the 300 cluster. 300 cluster looks better anyways and is digital
July 25th, 2015, 11:14 AM | #4 |
Awesome I'm sure I will be hitting you up regularly. I also hope to document the job in this thread, I guess I'm just not sure where to start lol
July 25th, 2015, 11:38 AM | #5 |
take the old motor out from both bikes and get ready for the swap. Take my advice and strip the bikes down completely. You will need access to every part of the bike for the wiring and taking the motor out.
July 25th, 2015, 05:41 PM | #6 |
Freedom for Germany
Unlike @EMSRacer07 I would go the different way and start with the cable, wire and hose routing before the engine is mounted.
You can find that all described with the pictures in the Appendix-Sections of the 300 Manual. |
Need advice/tips on buying my first Ninja 250R | TopGun_BK | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 19th, 2015 01:58 PM |
Advice needed on engine work | zzr | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 6th, 2014 07:14 PM |
250 Tips needed here @*^%! 300 | dreezo560 | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 31st, 2012 07:02 PM |
MSF course tomorrow. tips? advice? | EthioKnight | Riding Skills | 46 | January 20th, 2012 10:21 AM |
Crashed New 250R/Advice and Tips | Dino | New Members | 18 | September 11th, 2010 10:48 AM |
