#1 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 250r Posts: 69
Question about main jets
Hey guys I just finished my custom exhaust that I made using the instructions from a different site (sorry, I swear this is my favorite site though!!!) Ok so here's the dyno results from the original exhaust it's in a post in the upper middle of the page.
http://www.newninja.com/modification...r-(video)/135/ As you can see there is a loss of torque and horsepower in-between 8k and 10k rpms. Now I'm also going to take out the snorkel and my question is what size main jet do you guys think I should use to fix the flat spot in the rpm range?
"When I die I want mud on my jump boots, magazine empty, and barrel hot." |
#2 |
use the stock main jets (98).
Raise the needles on clip position (lower the clip) to take care of the flat spot. is your jetting completely stock now? |
#3 |
Yes it's totally stock (I'm such a slacker I haven't even shimmed the needles). But would raising the needle effect the rpm range that high? Also will #6 washers work for shimming?
"When I die I want mud on my jump boots, magazine empty, and barrel hot." Last futzed with by Tubesock; July 8th, 2009 at 06:20 PM. Reason: Additional question |
#4 |
If I had to guess, I'd say you're going to need to go up on main jet size, but you should try popping a couple of washers under the needles first.
Use #4 washers. They're the right size and cost about a nickel each. Wes |
#5 |
Join Date: May 2009 Motorcycle(s): 09 ninja 250(red) Posts: 193
#6 |
As far as the main jet goes what would be a good size to try first?
#7 |
keep the stock. the bike is rich on the top end as delivered.
you need to fatten up the midrange, which is the needle circuit. |
#8 |
Oh ok I get what you're saying now.
#9 |
Join Date: Apr 2010 Motorcycle(s): 2009 250 Ninja Posts: 24
I have a problem of jets getting clogged. Is it the main jet I need to replace?
Someone suggested getting slow jet #38 or 40 will fix the problem. |
#10 |
clean the carbs. problem solved.
#11 | |
![]() Don't let me stop you, but I prefer to address fixable problems only once! |
#12 |
Just replacing pilot jets won't necessarily do the trick. There's little passageways that are used during various throttle openings that also get clogged. You'll only have to do it once as long as you're careful to not let it sit for months without draining the carbs and stabilizing gas.
I've only cleaned mine once and since it gets ridden regularly and properly winterized every winter, I've never had to clean them again since. |
[crash.net - MotoGP] - Michelin front main question for 2016 | Ninjette Newsbot | Motorcycling News | 0 | November 20th, 2014 11:21 PM |
[crash.net - MotoGP] - Michelin front main question for 2016 | Ninjette Newsbot | Motorcycling News | 0 | November 20th, 2014 11:10 PM |
Main jet question | pdxdavid | 2008 - 2012 Ninja 250R Tech Talk | 1 | October 24th, 2013 05:15 AM |
WTB: Factory Pro 110 main jets | soundsfasterthanitis | Items Wanted | 8 | April 24th, 2012 02:25 PM |
Where can I purchase individual main jets? | 00v_Lucky | General Motorcycling Discussion | 17 | April 22nd, 2012 09:00 PM |
