August 19th, 2015, 10:04 PM | #1 |
Join Date: Aug 2015 Motorcycle(s): 2011 Ninja ex250r Posts: 8
Bike feels like it rolls with friction in first with clutch in
If you have been following my chain of threads you know that my bike chain popped while I was riding 30MPH also causing a lot of collateral damage and jamming my chain in between my engine block at 30MPH as well. I was able to finally get the chain out and put a new one on, along with a new front and rear sprocket but now it wont start, even worse when its in first gear and has the clutch fulled depressed it will hardly roll. its not completely free. Any idea on what I can do? I feel like I may have to salvage the bike but I hope not...
TL;DR : The bike will go into first, but has trouble rolling even when the clutch is fulled pressed in. |
August 19th, 2015, 10:07 PM | #2 |
Private Joker
MOTM - Mar '14
The clutch/transmission may be damaged from any added tension on the chain before it broke. I take it the engine block was undamaged from the chain
it rolls fine in neutral but not with the clutch lever in in first? have you tried adjusting the clutch lever/clutch line? does it ride normally once you get it into 2nd?
August 19th, 2015, 10:15 PM | #3 | |
cadd cadd cadd
MOTM - May '15
"the clutch is fulled pressed in". What does that mean? What is pressing it? Are you referring to the actual clutch or the clutch lever?
Riding it like I financed it. |
August 19th, 2015, 10:18 PM | #4 | |
I cant even pop it in 2nd. I think the problem there is that I cant start the bike. Or should I be able to even when the bike is off? its a 2011 |
August 19th, 2015, 10:20 PM | #5 |
Private Joker
MOTM - Mar '14
definitely sounds like clutch damage
August 19th, 2015, 10:28 PM | #6 |
August 19th, 2015, 10:30 PM | #7 |
Private Joker
MOTM - Mar '14
I can't tell without actually seeing it, it's possible that the damage is minor or extensive. I'd take it to a shop or a friend that knows bikes well to open it up and check it out
August 20th, 2015, 06:10 AM | #8 |
Join Date: Dec 2013 Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD) Posts: A lot.
WAIT!
Please clarify what exactly is being done (action) and what happens (reaction) You stated that the bike will not start---is the bike running when you are "rolling in first"? You will not be able to shift into any gear other than first and nuteral without the motor running due to the positive N finder on Kawasaki bikes. When the motor is not running and the bike is in first, it can be harder to push the bike than nuteral even with the clutch lever pulled into the handlebar because for drag of oil on the clutch plates. Please answer the questions and the answer will be provided |
August 20th, 2015, 07:11 AM | #9 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
isn't the neutral switch under the cover?
the kickstand switch is over there. either one with damaged wiring could keep it from turning over. the clutch is on the other side of the bike. I doubt it's messed up.
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
August 20th, 2015, 08:15 AM | #10 | ||
EX500 full of EX250 parts
Summary: A few sentences describing the problem. Steps to reproduce: List the actions you did, in order, for this situation to happen. Desired results: What did you expect to happen after doing the above steps? Actual results: What actually happened when you did those steps? Reproducibility: How often does this outcome happen? Every time? Most of the time? Occasionally? Can't get it to do it again? Quote:
Assuming the clutch switch is working, having the clutch pulled will allow the bike to start and run regardless of the state of the other switches.
August 20th, 2015, 10:09 AM | #11 | ||
Join Date: Nov 2012 Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000 Posts: 327
You said your motorcycle "wasn't so fortunate", what all was damaged? Sounds like you chewed up the front sprocket and the chain cover, in the world of starter bikes like the ninjette that's really not much damage at all. Hell all you need to buy is a sprocket and a chain, should be riding it again with an afternoon of work. Was there anything on the engine case or electrical that was damaged? The clutch located on the opposite corner of the engine from the output shaft, I don't see how a chain could damage it. First the non-start: I'll assume this means it won't turn over. Meaning you turn on the ignition, turn on the kill switch (don't ask me why I ask!), pull in the clutch and hit the starter button and nothing happens. Do the warning lights come on? Does the green neutral light come one? Do you get a click out of the solenoid close to your right ankle? How is your battery? Or is it turning over and just failing to start? Much more complicated question if so. Now the dragging in gear thing: There's usually a little drag on the wet clutch in first. Like when you shift a running bike from neutral to first, a lot of bikes will lurch forward just from the drag on the disengaged clutch. It's even worse on a cold bike where the oil between the clutch plates is extra thick and sticky. I know my EX250 drags enough when it's cold it's A LOT harder to roll in first gear than it is in neutral. Do I understand correctly that you're trying to turn the output shaft (where the small drive sprocket that was damaged went) with one hand while holding the clutch in with the other? I don't think you have enough leverage to turn it with an operable clutch. Especially if you're just grabbing the shaft with your hand (as opposed to the sprocket), you can put a lot more torque on the output shaft by putting it all back together and just rolling the bike. I'm really concerned that you've noticed this only because you've been in there wrenching on stuff; that in reality nothing is wrong with the clutch. Get a new sprocket and chain installed first, and if the clutch is failing to disengage then we'll start back on that problem. LT;DR: Fix the problem you're sure of first. Quote:
Oh god the bikes are multiplying!!! |
August 20th, 2015, 02:33 PM | #12 | |
August 20th, 2015, 03:11 PM | #13 |
cadd cadd cadd
MOTM - May '15
You're not helping us help you.
August 20th, 2015, 04:26 PM | #14 | |
You seemed to answer the question about the bike not running when the clutch was "dragging" (I am only guessing based on your statement not a direct answer) When you try to start the bike is the kick stand up or down. Bike in neutral or gear? if in neutral is neutral light on dash lit? have you tried the choke? Do you smell gas in the exhaust fumes? have you checked if the fuel is on prime or run? All we can do is guess when you say "It will not turn over but its close" Make sure you have a fully charged battery, put bike into N and be sure green light is on on the dash then hit the emergency engine stop first to stop then to run and then hit the starter for a few seconds----smell exhaust if it does not start--see if it smells of strongly of gas or smells normal. Provided the bike did not start try the choke and repeat then report back with as many details as possible! If it was running then there is only a minor issue preventing it from running now |
August 20th, 2015, 04:54 PM | #15 |
MOTM - June '15
Turning over means the starter is turning and the engine is rotating.
Starting it means it turned over and is now running. So, if it's not turning over, it's not close to starting. If it's turning over but not starting, there are other problems. If the bike was on its side, it can be hard to start sometimes.
August 20th, 2015, 05:10 PM | #16 | |
August 20th, 2015, 05:50 PM | #17 |
MOTM - June '15
Exactly. But we have no idea what's happening, so I gave some definitions to get everyone on the same page. Which we clearly are not.
Adjust clutch lever friction zone towards the bar | Whiskey | 2008 - 2012 Ninja 250R Tech Talk | 8 | August 8th, 2012 11:25 AM |
Clutch feels wierd? | codestp202 | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 20th, 2012 01:06 PM |
I think I need clutch service/friction plates replaced. :( | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 22 | July 22nd, 2011 01:06 PM |
Clutch friction point | peter330 | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 10th, 2010 05:04 AM |
