September 26th, 2015, 06:54 PM | #1 |
Join Date: Aug 2011 Motorcycle(s): '09 Ninja 250R Posts: 260
Bought a rear seat cowl, but there's parts missing?
I bought a rear seat cowl from a local store, but the rubber grommets are missing, and the triangular seat pad is missing. I think the lock pin is also missing.
Is this normal, do these things really need to be ordered separately, or should it have come completely assembled? . |
September 26th, 2015, 07:29 PM | #2 |
Track Clown
MOTM - Sep '15
should all come with the cowl
September 26th, 2015, 07:34 PM | #3 |
Join Date: Oct 2014 Motorcycle(s): 09 Ninja 250 & 1984 Harley Ironhead 1000 Posts: 28
I bought an OEM Kawi cowl and it included everything needed to install it.
September 26th, 2015, 09:38 PM | #4 |
Return it, and find a complete one, I'm guessing the one you have was on sale/cheap, know you know why.
Hopefully you can return it.
October 9th, 2015, 08:15 PM | #5 |
An update on this situation.....
The seat cowl was ordered directly from Kawasaki, who said they had the part in stock one day, and out of stock the next day. Now the only thing they offer is a "parts kit" where you have to order each individual part, and each part has a drastically inflated price, totaling more than double the original assembled cost of the seat cowl. Just the seat pad and all the hardware to make the cowl fit and lock down (grommets, screws, etc.) was over $150, and the cowl itself was over $100. And no, I didn't pay extra for those parts, the dealer is making Kawasaki fix the order at Kawasaki's expense. $250 for a complete rear cowl parts kit when the MSRP for the assembled cowl is half that??? WTF are they smoking over at Kawasaki these days??? |
October 9th, 2015, 09:46 PM | #6 |
ChocolateMilk Addict
Join Date: Mar 2015 Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock" Posts: 329
idk, but i want some
< ATGATT > Sweat you can wipe off, Road rash you can't. Burn Rubber, not your Soul. |
October 12th, 2015, 09:03 AM | #7 | |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
October 12th, 2015, 06:30 PM | #8 | |
Even the guys at the bike shop expected the cowl to arrive fully assembled. |
October 12th, 2015, 09:00 PM | #9 |
MOTM - Oct '15
Yes, that is ridiculous!
December 10th, 2015, 09:47 AM | #10 |
So I FINALLY received all the parts for my cowl after the main lock bar was on back order for 2 months, but no assembly instructions....
So can anyone who has the official Kawasaki rear seat cowl please post some close-up pics of the underside of their cowl so I can get this thing assembled? |
December 18th, 2015, 11:57 AM | #11 | |
Join Date: Dec 2015 Motorcycle(s): Kawasaki Ninja 250r Posts: 13
Hey man, that was very weird. When I bought the seat cowl, like the other guys, it came with all the parts. Here are the original instructions manual. It's an easy procedure, and in 15 minutes you got the seat ready to install. EDIT: When I uploaded the images here, they were compressed, and possibly you won't be able to read them. Here are the same images uploaded on other site (better quality): Hope you can assemble it! |
December 22nd, 2015, 10:54 AM | #12 |
I have 2 sets of rubber dampers, 1 pair is taller and smaller in diameter, and the other pair is wider in diameter but much shorter.
It looks like those instructions say to put the shorter wider ones in front on the locking pin bar, and the others on the back. When I did that nothing fit right when I tried to put the cowl on the bike, but when I put the taller ones on the locking pin bar, it fit just right. I'm just worried about how loose these rubber things fit.... |
December 22nd, 2015, 04:56 PM | #13 |
Mmm, are you sure that these rubber dampers are the correct for this seat cowl, right? (I don't think that they've sended a wrong ones). The big (diameter) rubber dampers, like the manual says, go on the front, like in this picture:
Be careful on fitting the rear part of the seat. You must do it very gently or the "O-ring" can leave out. In this case, try put some grease on it. If you can lock the front pin (you can do a slightly force to get it), then the rubbers are OK. If not, I am thinking that these rubbers have something weird.. |
December 22nd, 2015, 07:35 PM | #14 |
I compared the rubber damper height to the original rear seat. Comparing the height of the locking pin to the height of the dampers on both locking bars.
When I used the taller dampers in the front it matched the height of the dampers on the original rear seat, and it locked in place just right, no wobbling around. When I used the shorter dampers in the front it was too low and wobbled around in the lock once installed on the bike. For now I think I'm going to stick with the taller ones in the front, and maybe secure all the dampers in place with some rubber cement so they won't fall out. And I've heard many stories about that O-Ring grommet getting lost, that's why I used some black Gorilla Tape to hold it in place underneath so it can't be seen. |
December 25th, 2015, 11:54 PM | #15 |
All right, if you don't lose these rubbers and if the seat fits good, then I think it's good enough.. these rubbers are only to "rest" in the chasis so it's no problem.
Merry Christmas! |
various help: radiator cowl panel, rear seat cowl | 95PGTTech | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 22nd, 2015 02:21 PM |
Rear seat / Seat cowl raised? | PloXyZeRO | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 4th, 2014 08:36 AM |
CHEAP....Rear seat cowl, front cowl, rear sliders, LED MIRRORS | joes280 | Motorcycle-related | 11 | April 27th, 2012 09:42 PM |
TRADE: My rear seat for a seat cowl | azimmer11 | Items Wanted | 0 | August 17th, 2011 05:20 AM |
Fender Eliminator, Corbin Seat, Rear Seat Cowl Installed | k-os | Pictures | 9 | February 10th, 2009 08:56 AM |
