May 2nd, 2016, 09:47 AM | #1 |
Join Date: Apr 2016 Motorcycle(s): 01 Ninja 250 Posts: 69
Fuel drip from carbs, not from the drain....
Seems like it's more towards the top of the bowl. Previous owner owned the bike for 6 years and did his own carb cleaning and had just done these before I bought it a couple weeks ago. I don't know him personally, but I assume he knew what he was doing since he's done it many times before.
Any ideas as to what and where I should be looking at? The attached pictures show where there is fuel accumulated (tip of screwdriver). Also the fuel smell is not constant and I only notice it occasionally. The bike runs and drives just fine. |
May 2nd, 2016, 09:50 AM | #2 |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
Fuel Bowl o-rings?
Because Unregistered sucks at riding. |
May 2nd, 2016, 09:51 AM | #3 |
Vintage Screwball
MOTM - Mar '16
I would say either float bowl gasket OR the connector pipe between carbs has a leaking o-ring seal.
Part 92005B in this fiche: http://www.bikebandit.com/oem-parts/...49469#sch66422
Goin' fast on slow bikes! |
May 2nd, 2016, 10:01 AM | #4 |
I'll clean it up and see if I can get a better idea of where it's coming from.
What to attack next? (Carbs/Fuel) | fynflood | 1986 - 2007 Ninja 250R Tech Talk | 14 | May 24th, 2013 10:26 AM |
Should I drain the carbs even though... | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 14th, 2013 02:56 PM |
fuel tank drain | John D | 2008 - 2012 Ninja 250R Tech Talk | 2 | October 30th, 2012 10:09 AM |
How Long Does it Take For the Reserve Tank To Drain Carbs ?? | RedNinja09 | 2008 - 2012 Ninja 250R Tech Talk | 34 | July 20th, 2011 10:00 AM |
Leaking fuel from carbs | haze5736 | 1986 - 2007 Ninja 250R Tech Talk | 18 | July 19th, 2011 07:34 AM |
