September 16th, 2009, 04:36 AM | #1 |
Please help me trouble shoot!!!~~~
Hi guys. Well... it started about a 2, 3 months ago... accelerating is fine, but staying on constant speed sometimes bogs a little.. then... it bogged more and more (only constant speed). Then, it started to bog in idle during cold start and shuts itself off... Then, recently, it just wouldn't stay alive, couldn't even able to make it out the drive way.
So, I took this bitch apart, pull the carbs out, thinking maybe give the jets a real good clean might able to fix it. Floats out, needle jets out, pilot jets out, pilot screws out... and they are all pretty much sparkling clean O_o Looked through the jets, and I see the light on the other side... The light through is about the size of a sugar powder. So it should be good right? Anyway, I'm still soaking them in carb cleaner.... not sure if it'll make the hole bigger or whatever... but it doesn't look like dirty carbs is the problem.. What else could cause that problem!??!?!!? Please help! |
September 16th, 2009, 04:44 AM | #2 |
Join Date: Feb 2009 Motorcycle(s): 2009 250r SE, 2015 FJ-09 Posts: 171
if that doesnt fix it you probobly have a spark problem. thats where i would check. also have you done any mods to the bike. ie exaust, filter as this could be throwing off your jetting.
September 16th, 2009, 09:31 AM | #3 |
check your air filter.
also, when was the last time the valves were adjusted? |
September 16th, 2009, 09:31 AM | #4 |
Bogs
You might want to check the vacuum diaphrams in the carbs. If they have a tear in them, it won't run well until high RPM's and full throttle. Sort of like a two stroke going in and out of its power band.
September 18th, 2009, 12:17 AM | #5 |
Humble Observer
Join Date: Mar 2009 Motorcycle(s): 2009 Yamaha XT250 Posts: 612
+1. Welcome to the valve adjustment bandwagon, kkim!
Everything I post is "IN MY HONEST OPINION". Why is "Parking Lot Enduro" not a thing? |
December 3rd, 2009, 12:14 PM | #6 |
OK, so I just came back home 2 weeks ago and here's what I did:
Since the carb was pretty damn clean, I just put everything back together. Took the fuel pump out, get it tested OK. Changed a fuel filter. Took the battery out, and it was also tested OK. Spark plugs are all OK looking. So without any other clue, I brought the bike to a shop and the dude found out my carb was leaking gas at the part where the tub from the pump connected to the carb. There was a crack and he simply just glued it close. So it's running fine now. =) |
December 3rd, 2009, 12:18 PM | #7 |
mmmm.... what kind (yr/model) of bike do you own? it says "none" under your info.
You're saying your float bowl was cracked? If so, I'd say get another float bowl and don't trust the glue to hold. Gas is a very strong solvent. |
Did a little shoot this evening | BearZ | Pictures | 5 | August 20th, 2012 09:09 PM |
CW Magazine 250 Shoot out | Sailariel | General Motorcycling Discussion | 42 | March 11th, 2011 03:52 PM |
Photo Shoot | 10.101RS | Pictures | 11 | April 3rd, 2010 07:30 AM |
How NOT to shoot a Desert Eagle 50 | g21-30 | Off-Topic | 7 | March 6th, 2009 07:33 AM |
[superbikeplanet.com] - Crap. Shoot. | Ninjette Newsbot | Motorcycling News | 0 | September 14th, 2008 11:17 AM |
