May 12th, 2017, 01:07 PM | #1 |
Join Date: Jul 2016 Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6 Posts: 210
Small hole in airbox -- how to seal it?
I went to go change my coolant and took off the overflow tank. Noticed a bunch of oil residue on the backside of the tank, as well as around the corner of the airbox. Then I found this small hole:
What's the best way to seal it up? P.S. I think my coolant really needed changing. The overflow tank even had a bunch of crap inside.. |
May 12th, 2017, 01:37 PM | #2 |
Does that actually go through to the inside?
May 12th, 2017, 02:17 PM | #3 |
May 12th, 2017, 02:49 PM | #4 |
Some ideas:
Put a sheet metal screw in it. Degrease it and put a glob of silicone sealer on it. It won't stick well, so leave enough outside so it won't migrate into the box. Degrease and fill it with hot glue. This is probably the best of these three, since it's likely to stick somewhat. |
May 12th, 2017, 03:24 PM | #6 |
May 12th, 2017, 03:53 PM | #7 | |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
An alternative quick-fix would be to simply melt the corner over the hole. |
May 12th, 2017, 04:20 PM | #8 |
I'll be interested in what you find out. I'm thinking you're probably right.
May 12th, 2017, 06:40 PM | #9 |
Join Date: Apr 2014 Motorcycle(s): 1978 Z1R, 1999 EX250 Posts: A lot.
MOTY - 2018, MOTM - Oct '16
Sounds like a job for duct tape.
May 12th, 2017, 07:37 PM | #10 |
MOTM - July '15
Aren't there guys who drill holes in the airbox of their Honda cages to make them "go faster" ?
May 12th, 2017, 07:45 PM | #11 |
May 13th, 2017, 03:17 AM | #12 |
It's after the filter. Sure, it's "wrong", but it doesn't seem to be causing any real issues. Don't worry about plugging it, we all have one. Pretty sure it's a drain hole or swirl hole or something like that.
Small enough it doesn't matter anyways. |
May 13th, 2017, 05:40 AM | #13 |
Join Date: Dec 2015 Motorcycle(s): 2008 Ninja 250 Posts: 210
JB weld ?
May 13th, 2017, 10:28 AM | #14 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Black silicone sealant: easy to remove If you change your mind.
Round front hole on airbox? | baz666 | 1986 - 2007 Ninja 250R Tech Talk | 7 | March 23rd, 2014 03:21 PM |
FREE right side clutch cover (with only 1 small hole in it)! | PartsNinja | Free stuff! | 3 | September 13th, 2013 12:20 PM |
Is this supposed to be here? (hole in pregen airbox) | Insan3guy | 1986 - 2007 Ninja 250R Tech Talk | 10 | July 15th, 2013 04:34 PM |
OEM Brand New Fork Oil Seal, Dust Seal (08-12) | capriccio | Motorcycle-related | 3 | June 9th, 2013 05:11 AM |
small hole in vacuum piston which way do they point? | fixture | 1986 - 2007 Ninja 250R Tech Talk | 4 | December 1st, 2009 12:44 PM |
