September 22nd, 2009, 07:38 AM | #1 |
Oil change
Where do you guys dispose of your old oil? And can you buy all the necessary parts for the oil change at a local Pepboys or Autozone or you have to get them at the dealer? Thanks dudes.
September 22nd, 2009, 07:44 AM | #2 |
Join Date: Jul 2009 Motorcycle(s): 2009 Kawi Ninja 250, Blue Posts: 28
I got my filters through my dealer.
Take your old oil to Autozone. They should have a recycling tank in back for you to pour it in. Might be able to take the old filter as well. |
September 22nd, 2009, 08:39 AM | #3 |
Join Date: Jan 2009 Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock Posts: A lot.
i heard some places gots these containers you can pour used oil into for turn-in..some sorta uber-absorber container...not sure though.
Remember when sex was safe and motorcycles were dangerous? |
September 22nd, 2009, 08:59 AM | #4 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
Almost all auto parts stores are oil recycling drop points. Just walk in with the oil in covered container, and they will take you to the back were you can pour it into a great big container.
Addicted to anything that has an engine and rolls. |
September 22nd, 2009, 03:26 PM | #5 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
Check the DIY section (http://www.ninjette.org/forums/showthread.php?t=5586) for all the tips you will need on oil changes. Bottom line is you will find oil/filters/o-rings at "other stores" way cheaper than the dealer.
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
Is it normal for oil to increase a bit in the crankcase after an oil change? | cadd | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 15th, 2014 08:38 PM |
Synthetic oil at 300 mile oil change? | anacron | 2013 - 2017 Ninja 300 Tech Talk | 14 | July 29th, 2013 04:58 PM |
Oil drain plug gasket for oil change. | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 10th, 2012 01:00 PM |
Oil Change | Honko | 2008 - 2012 Ninja 250R Tech Talk | 10 | July 17th, 2011 08:58 AM |
change oil filter, without draining oil? | peter330 | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 30th, 2010 01:08 PM |
