October 18th, 2017, 08:45 PM | #1 |
Join Date: Jul 2017 Motorcycle(s): 2003 Ninja 250R Posts: 32
GVEs - Worth it?
Has anyone installed GVEs in their forks? If so, I'd love to hear your before/after experiences and whether they're worth the expense.
October 19th, 2017, 05:44 AM | #2 |
Join Date: Oct 2015 Motorcycle(s): 16' S1000RR, 04' CB919, CRF150/230, 07' 250R Posts: 41
To get right to the answer for you, over a stock set up, yes they are very much worth the investment. I would personally suggest something for the rear at the same time (either a new gen shock swap or GSX-R shock swap).We did ride them bone stock for a short period and while soft, and bouncy, they are serviceable for track riding even bone stock and soggy.
To give more detail though and offer a second solution: We have a slew of pre-gen 250’s in our camp with various states of tune but here is what we have and my personal take on the set ups. I have not ridden any of these on the street, only at the track. YMMV All have GSX-R rear shocks tuned to the owners riding preference for feel and tire wear. Front suspension is set up as follows: 1 with GVE, cut stock springs to get roughly .70 and if I recall, 30wt fork oil. Not sure what pop off spring is being used. This is stiff, hydraulic stiff. Originally it had 2” cut off the stock springs and a lighter weight oil but was somewhat softly sprung. This setup offered good compliance and feel but was soft for hard braking. Stiffer springs were added but then the rebound wasn’t enough to slow down the return stroke. Thicker oil was added to calm the rebound and that worked great but now it feels hydraulically stiff on compression and does not offer the feel of the softer set up. This is running RS10 tires. I’m sure this will get sorted out over winter to soften it back up. 1 with GVE, .75 Sonic springs, 30wt fork oil. Not sure what pop off spring is being used. This is stiff, hydraulic stiff. Originally it had 2” cut off the stock springs and a lighter weight oil but was somewhat softly sprung. This setup offered good compliance and feel but was soft for hard braking. Stiffer springs were added but then the rebound wasn’t enough to slow down the return stroke. Thicker oil was added to calm the rebound and that worked great but now it feels hydraulically stiff on compression and does not offer the feel of the softer set up. This is running Alpha 13 tires. I’m sure this will get sorted out over winter to soften it back up. Essentially the same set up as above but with different springs. They feel very similar to each other (as they should being set up almost identical). 1 with Ricor Intiminators, 2” cut off stock springs, 5wt oil. This bike is pretty well sorted and offers good feel on the front. This is running Alpha 13 tires. This is a softer sprung but very well damped set up. Stiffer would be nice on this set up to hold the front up under hard braking better but otherwise a good set up with lots of feel. 1 with Ricor Intiminators, .75 Sonic springs, 5wt oil, forks lowered in triples, Big Boy links to raise bike 1” at the pegs. This bike is running SuperCorsa tires. This bike offers the best compromise (in my opinion, the others may chime in and prefer their own set up) of stiff yet compliant. Offers fantastic front end feel and bump compliance while supporting the front end well under hard braking. This is my personal choice for best feeling setup for fast laps. This set up offers almost the same feel as above (as it should being set up almost identical) but with better chassis support with the stiffer front springs. IMO, the Ricor set up is the way to go. No, you cannot tune them like you can the GVE, but in my experience it looks like you don’t need to in order to achieve a great feeling front end. If you spend enough time with the GVE I’m sure they can be tuned to be as good or better than the Ricor but to get going with little fuss, get the Ricor and enjoy your new suspension. |
October 19th, 2017, 06:37 AM | #3 | |
I realize I should have defined my current setup in my original post. I have 0.75 Sonic Springs and my damper rods are unmodified. Based on my read of the Ricor website, it appears you can drop in the Intimidators without modifying the damper rods. Is this true? If so, that makes them far more appealing than GVEs as far as ease of installation is concerned. Also, it seems that with my springs, 5wt oil is the way to go - do you agree? |
October 19th, 2017, 07:24 AM | #4 | |
I forget the oil height I went with but will find out and post it up for you to try. If Z1R Rider sees this, he can post it because I went the same height as his. They are as easy to install as you read. |
October 19th, 2017, 09:56 AM | #5 |
it's been a while since I modified my EX250's suspension but I clearly remember how completely awful the OEM suspension was. a wallowing, floppy cow really.
but I also remember my feeling about the bike when I first upgraded the front suspension. I immediately realized that only doing the front wasn't enough. doing the front without doing the rear shock only made me constantly aware of how bad the OEM rear shock is. after I upgraded both the front and rear the EX250 suddenly became a great bike. you have to do both ends of the bike. |
October 19th, 2017, 12:04 PM | #6 | |
October 25th, 2017, 01:09 PM | #7 |
I did it but at the same time I also upgraded the springs and the weight of the fluid so not sure which is the most important. Do know I would never go back to stock You might consider just upgrading the springs and fluid first and seeing how you like it.
[tilted horizons] - A Job Worth Doing is Worth Doing Twice | Ninjette Newsbot | Motorcycling News | 0 | July 17th, 2015 10:20 AM |
is it worth it? | SafetyPaws | 2008 - 2012 Ninja 250R Tech Talk | 35 | September 11th, 2012 06:58 PM |
Could it be worth it? | KawiKid860 | General Motorcycling Discussion | 1 | September 10th, 2012 05:10 AM |
what's it worth? | bamaland | General Motorcycling Discussion | 32 | September 12th, 2010 08:54 PM |
What's it worth? | 09black250 | General Motorcycling Discussion | 9 | March 22nd, 2010 05:50 AM |
