Old December 9th, 2017, 12:12 PM   #1
Frank06
Motorcycle(s): many!
[300] Anybody Using O2 Sensor to Collect Data?
I just bought a 300 Ninja as a race bike. It has a slip-on and a PC5, so the stock O2 sensor isn't really doing anything. Is anyone using the sensor to grab data? Any hints appreciated!
TIA
Frank06 is offline   Reply With Quote
Old December 9th, 2017, 12:25 PM   #2
Stock O2-sensor is still in use everywhere except at WOT. It only provides data to maintain 14.7:1 AFR under partial-throttle conditions.
If you want to gather really useful data for tuning and getting optimum power, then you'll want to install wideband O2-sensor after getting a full aftermarket exhaust system. Main bottleneck is factory exhaust and catalytic. With wideband data AND dyno-tuning, you can extract extra power from 300 with just fine-tuning the fuel-maps. As with carbed bikes, EFI bikes have factory set-up with way too much fuel under WOT in the high-end around 12.0:1 AFR
Leaning this out to 13.5:1 where NA engines make most power gets you an additional 4bhp! The PC is great because it lets you make +/- adjustments to fuel-mapping in 100-rpm increments. Such as subtracting 10% fuel at 8500rpm, removing 2% at 9700rpm and taking out 10% at 11000rpms. No way you can do that kind of fine-tuning to yield perfectly flat fuel-curve and major boost in power with carbs. That's 4 BHP or 13% more power from just a couple of mouse-clicks!!! buwahahahahahahaa
Old December 9th, 2017, 12:34 PM   #3
Frank06
Are you sure? I haven't followed the wiring but the installation instructions I saw online said to unplug the stock sensor (it's replaced with something called an O2 optimizer) and it could be removed if wanted.
I had assumed (hoped?) the stock sensor was wide-band but maybe not. The map it has now works but I thought it'd be interesting to check F/A ratio.
Old December 9th, 2017, 12:42 PM   #4
What year is your 300? I don't think the 2013-14 US models had O2 except for California?
WIth PC, it's an option to remove, but you'll have to do A LOT of re-tuning of entire fuel-map. Idle and partial-throttle from 10% to 90% throttle. That's like 1000 data-points you have to adjust. The factory ECU does that for you with O2-sensor. No need to re-do a lot of the factory's engineering for no better results.
What you're only really interested in adjusting is the 20-30 data-points under 100% WOT to match any mods you've done like exhaust, high-comp pistons, cams, larger-valves and porting, etc. You need a wideband O2-sensor with datalogging to record your AFR as you ride. A gauge or instantaneous display is not useful and can actually be very dangerous as it distracts you while you're doing 5th-gear full-throttle runs to redline. I like the TechEdge line of sensors from OZ because they are fully-digital (many on market are hybrid digital/analogue, not as accurate), and it has on-boad memory to datalog up to 30-minutes of data without needing a PC connected.
Old December 9th, 2017, 01:10 PM   #5
You can also buy a wideband from DynoJet that ties into their Power Commander and gives you auto-tuning and datalogging features (still need laptop hooked up). At which point, you're right back to same functionality as factory system with O2-sensor hooked up. Well, you can now adjust and save WOT maps.
http://www.powercommander.com/powerc..._autotune.aspx
Last futzed with by DannoXYZ; December 9th, 2017 at 02:39 PM.
New sensor data readings linkinpark9812 2008 - 2012 Ninja 250R Tech Talk 4 April 27th, 2014 01:45 PM
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter StaylorT 2008 - 2012 Ninja 250R Tech Talk 10 January 24th, 2014 12:38 AM
event data recorder on the 300....Really?? RockyCapone 2013 - 2017 Ninja 300 General Discussion 50 March 24th, 2013 04:43 PM
