Old March 3rd, 2018, 09:12 PM   #1
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Throttle Free Return Slow
I acquired a used 2008 250 with 2700 miles on it. It wasn’t idling and died with throttle so I pulled the carburetors to clean the jets. The throttle free return was fine before I took everything apart. But now it is slow to return - it no longer snaps closed. What did I do wrong?
geeker is offline   Reply With Quote
Old March 3rd, 2018, 09:53 PM   #2
geeker
geeker's Avatar
Never mind. Problem solved. I had the lower cable adjusters tighter than they were originally. I compensated at the throttle end and it was snappy once again.
Old March 4th, 2018, 02:56 AM   #3
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
Thumbs up
good deal
"trying not to get old"
Old March 4th, 2018, 11:41 AM   #4
geeker
geeker's Avatar
New problem: dumping fuel out of the overflow line while cranking. I am pretty sure I put everything back the way I found it. Would the float bowls get knocked out of adjustment just by opening them to access the jets?
Old March 4th, 2018, 11:46 AM   #5
Probably not, but I've had floats get hung up after having bowls off over the years. If that's the case, you might be able to drain the bowl and refill, and have it start moving freely again. I've also occasionally been able to tap on the bowl with a screwdriver handle and get it free. Otherwise I guess you need to open it again and see why the valve isn't closing.
Old March 4th, 2018, 01:15 PM   #6
cuong-nutz
cuong-nutz's Avatar
^^^ What he said. I too have gotten by with tapping the bowls to free the floats.
HalfFast Racing Team
Old March 5th, 2018, 11:57 AM   #7
geeker
geeker's Avatar
Where does the vent hose between the carbs route? I can’t find a mention of it in the service manual.
Rpm real slow to come back down after giving it some throttle bob706 2008 - 2012 Ninja 250R Tech Talk 5 November 15th, 2015 07:10 AM
Slow throttle response and slow return to idle help Crriiissss 1986 - 2007 Ninja 250R Tech Talk 22 August 7th, 2013 12:26 AM
[twisted throttle] - Get the 2012 Twisted Throttle Catalog Here - Free! Ninjette Newsbot Motorcycling News 0 February 13th, 2012 07:10 AM
[twisted throttle] - Get the 2012 Twisted Throttle Catalog Here - Free! Ninjette Newsbot Motorcycling News 0 February 10th, 2012 01:20 PM
slow return to idle red 2008 - 2012 Ninja 250R Tech Talk 4 April 9th, 2011 09:25 PM
