October 19th, 2009, 10:35 AM | #1 |
Made it into Web Bike World
Not really a big deal, but I sent this into the editor and he published it..ha ha
See the first comment, after the following link: http://www.webbikeworld.com/r3/motor...chain-cleaner/ From "S.M." (9/09): "I too got tired of using a scrub brush, etc. to clean my bike's chain. I had an unused sprayer (similar to this SureSpray) that I decided to try. I put a gallon of mineral spirits in the sprayer and pumped up the sprayer. Since mineral spirits is petroleum based, it doesn't hurt the rubber O-rings. With the bike supported on a rear bike stand, hold a cleaning/shop towel under a section of the chain and spray the chain. You can use the towel to clean that section and proceed to the next section of chain. Once the chain is relatively clean, I use a small air compressor (2 gallon) to blow dry the chain. Next apply Maxima Chain wax per the manufacturer's instructions. Since I started using the mineral spirits/sprayer, I have cleaned the chain twice and still have 2 or 3 cleanings left in the sprayer." |
October 19th, 2009, 01:41 PM | #2 |
Nice idea. Haven`t thought of Mineral Spirits---a damn sight cheaper than WD-40 (Bulk Variety. The aerosol has a substance in the propellant harmful to O rings) I have been using a spray bottle. Thanks for the tip. I`ll be using Mineral Spirits to clean my bicycle chains as well. I have got to be cleaning at least two chains a day in my shop--not to mention parts. Unbelievable how a great idea can be right in front of you and you don`t see it. Congrats on being published.
October 19th, 2009, 01:57 PM | #3 |
I hope you're waxing the bicycle chains! Less mess! Thanks
October 19th, 2009, 02:17 PM | #4 |
October 19th, 2009, 02:23 PM | #5 |
Little more time consuming, but I meant to break the bicycle chain and using a freewheel container (metal can) the freewheels come packaged in, place the chain in it, along with mineral spirits. Let it soak, until clean. Hang it up and air dry or speed it up with compressed air.
Buy bulk 1 lb blocks of wax at the grocery store and using a double boiler, put the block of wax in and heat it and the water, until the wax melts. Lower the chain into the hot wax with a clothes hanger. Let soak for a few minutes and hang to dry. Replace the chain. Reuse the wax a few times....save more money. |
October 19th, 2009, 02:58 PM | #6 |
MOTM - Sep '18, Feb '16
I use finish line on my chain also. But I don't have any O rings to worry about.
October 19th, 2009, 03:05 PM | #7 |
IC2(SW)
I havent cleaned the one chain in the 4 years of having the bike. Atleast it gets lubed often....... I suck!
October 20th, 2009, 02:54 PM | #9 |
If I break the bicycle chain, I usually put it into an emty soda bottle with a 50-50 mixture of Simple Green and water. I shake the bottle and change the liquid until the chain is clean. I then dry it with a compressor and lube it with Finish Line. If I only want to clean the chain while it is on the bike, I will go with the Mineral Spirits. Thanks for the great idea.
Here's all the changes I've made to my bike in the last 2 months :) | Obey Reaper | Pictures | 11 | July 27th, 2014 11:48 AM |
[motorcycledaily.com] - RideApart Web Site Spies a CTX1300 (Bike Reports) (News) | Ninjette Newsbot | Motorcycling News | 0 | October 23rd, 2013 12:50 PM |
[superbikeplanet.com] - World Superbike Series Web Launch On Now | Ninjette Newsbot | Motorcycling News | 0 | January 23rd, 2010 10:30 AM |
Bike No Longer Made That You Would Want | backinthesaddleagain | General Motorcycling Discussion | 38 | May 5th, 2009 10:18 AM |
[hell for leather] - Urban Rider launches bike clothing web store | Ninjette Newsbot | Motorcycling News | 0 | January 20th, 2009 02:00 PM |
