#1 |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
New Gen Valve Float
Recently I've noted a stuttering on my 07' above 13,000 R.P.M. I thought my main jets might be a-little lean. I'm pretty sure it's valve float. I have a tach that came from an older Pre-gen and is red lined at 14,000, not the 13,000 that the 07' is red lined at. Whatcha guys think - valve float?
Bill
Insanity: doing the same thing over and over again expecting different results each time. |
#2 |
Could you be hitting the rev limiter? I've found mine. It removes spark from one cylinder briefly.
#3 |
If your '07 has it's original CDI box then the engine will be limited to the late-pre-gen redline RPM.
#4 | |
Bill ![]()
Fixed valve cover bolt leak & valve clearances | Linkin | Videos | 3 | June 24th, 2015 03:49 PM |
Want a current gen 250r, but I'm afraid of valve adjustments | 249cc | 2008 - 2012 Ninja 250R Tech Talk | 19 | November 12th, 2012 02:04 AM |
Need a 2nd pair of eyes on pre-gen valve cover | bluepoof | 1986 - 2007 Ninja 250R Tech Talk | 2 | September 4th, 2012 03:27 PM |
WTB - Pre Gen Valve Adjustment Tool | Jim Moore | Items Wanted | 3 | June 20th, 2012 07:22 AM |
Carb - leaky float valve questions | ako | 1986 - 2007 Ninja 250R Tech Talk | 34 | June 15th, 2011 10:04 AM |
