Old July 30th, 2018, 06:45 PM   #1
Jpc647
Motorcycle(s): 07 Ninja EX250 , 2005 SV650, 2003SV1000
Wire going to coil - What is it?
This wire going to the coil. What does it do? The coil tab (that the wire clips into) has power when the ignition is on. If this is unplugged, the coil isn't firing, right?
Jpc647 is offline   Reply With Quote
Old July 30th, 2018, 06:48 PM   #2
Ceeloo Yello
Motorcycle(s): 250
Must be ground wire then.
Old July 30th, 2018, 07:22 PM   #3
Jpc647
It was more of a, how does that pin have power with the key on, if it's not connected. And, that must mean that cylinder isn't firing.
Old July 30th, 2018, 07:39 PM   #4
Ceeloo Yello
Motorcycle(s): 250
My understanding is the CDI pulses the ground wire to make the coil fire.
Old July 30th, 2018, 07:41 PM   #5
Ceeloo Yello
Motorcycle(s): 250
So yes if not connected, no spark.
Old July 30th, 2018, 07:53 PM   #6
Not CDI-capacitator discharge ignition system which send high-voltage +positive signal to fire coil that's always grounded. This is semantic confusion, like using "Kleenex".
Rather, it is Inductive Ignition which has advantage of much longer spark duration to guarantee ignition and complete combustion. This works by having coil always supplied with +12v to charge it (red wire). Then ignition box grounds other side of coil to fire spark (black wire). If you connect 'noid light to these wires (or use oscilloscope), you can see the grounding pulses.
Old July 30th, 2018, 07:58 PM   #7
That disconnected terminal has power because it's connected to one side of coil. Other side of coil is connected to +12v. Imagine replacing coil with piece of wire with 2 terminals, if you connect one end to +12v, other end would have +12v also right?
Since one side of coil is disconnected, no current flows, therefore no voltage-drop V=IR. Voltage is same on both sides of coil. Until disconnected side is grounded by ignition box. Then black wire drops to zero volts (see scope trace above).
Issue you want to track down is whether that coil is receiving grounding pulses. Oscilloscope is alway my first choice because it shows not only binary yes/no "yeah there's pulse alright" like 'noid light, but it also gives me quality of signal such as duration and completeness of grounding pulse. Which can help narrow down issues with shorted wiring or bad coil problem.
For now, just plug disconnected wire back into terminal and see if it runs smoothly on both cylinders.
If not test for spark: pull plug-wire, stick known-good plug into it, ground case of plug by laying on top of engine, then crsnk engine. Also do test on other cylinder as control.
Last futzed with by DannoXYZ; July 30th, 2018 at 10:05 PM.
Old July 30th, 2018, 07:58 PM   #8
Jpc647
Okay. Thanks guys. I may have taken the carb apart and cleaned it for no reason.... :/
Old July 30th, 2018, 08:13 PM   #9
ALWAYS good idea to completely disassemble carbs to clean!!!
Old July 30th, 2018, 11:12 PM   #10
Ceeloo Yello
Motorcycle(s): 250
True but almost everyone refers to it as the CDI.
Old July 31st, 2018, 06:14 AM   #11
Jpc647
Sure. I've taken the float bowls off, and they are perfectly clean. There's not a spec of gunk in the bowl, and the floats look new. This carb isn't gunked up. I'm going to clean it a bit, without a total disassemble, and put it back on, make sure the coil it on, and give it a whirl. I'll throw new plugs in too.
Kawasaki ZX Ignition Coil Pack/ coil over plugs (CoPs) modification. Ghostt 1986 - 2007 Ninja 250R Tech Talk 44 June 10th, 2019 03:48 PM
[American Motorcyclist Association] - Near-perfect wire-to-wire effort gives veteran Ninjette Newsbot Motorcycling News 0 March 11th, 2015 07:40 AM
coil and plug wire help gantt 2008 - 2012 Ninja 250R Tech Talk 7 March 5th, 2015 07:50 AM
Ignition coil wire leads headshrink 2008 - 2012 Ninja 250R Tech Talk 7 June 25th, 2014 05:59 PM
Coil Wire Inquiry Greyfox 2008 - 2012 Ninja 250R Tech Talk 5 January 23rd, 2013 05:01 PM
