Old November 1st, 2018, 05:45 PM   #1
steven moore
Motorcycle(s): 07 250 ninja- honda forza 300
250 ninja trike
What's up guys I thought I'd share my latest project powered by 07 250 Ninja. I think I might have posted it before when it was still under construction, but now that I have a few miles on it and it's more complete...
steven moore is offline   Reply With Quote
Old November 1st, 2018, 05:51 PM   #2
steven moore
Here's some more pics
Old November 1st, 2018, 06:08 PM   #3
Ceeloo Yello
Motorcycle(s): 250
That is insane.
Old November 1st, 2018, 06:14 PM   #4
steven moore
Lol, don't ever let me get bored with a welder and grinder. Here's a list of Parts in no particular order. Stock ninja front end, stock ninja engine, stock ninja tank, 1 inch rear go-kart axle, stock rear Ninja master cylinder, go-kart hub with motorcycle sprocket mounted, bucket seat from Jegs, rear trailer tires and rims that are rated for 1650 lb , suicide shifter with clutch, ammo box to hold Electronics, go kart rear disc that matches ninja rear caliper, and stock ninja exhaust that have been modified. And a few other things that I probably can't remember right now
Last futzed with by steven moore; November 1st, 2018 at 06:21 PM. Reason: Had to add to the Post
Old November 1st, 2018, 06:26 PM   #5
Ceeloo Yello
Motorcycle(s): 250
Maybe add some rear fenders would be cool.
Old November 1st, 2018, 06:28 PM   #6
steven moore
absolutely I need to, I may attempt that tomorrow it needs to get done it's the only law I'm breaking LOL
Old November 1st, 2018, 06:57 PM   #7
Snake
Snake's Avatar
Looks good!
Old November 1st, 2018, 07:21 PM   #8
steven moore
Thanks! It runs good too. It grabs attention every where I go. No suspension in the rear can get annoying on rough roads but I take it on the freeway a lot it does pretty well. Top speed of 80 mph. The farthest I've ever driven it so far is about 60 miles over a mountain to the next town over.
Old November 1st, 2018, 08:55 PM   #9
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Really cool!
So it's got a solid rear axle?
Old November 1st, 2018, 09:01 PM   #10
steven moore
Was a solid rear axle I had to cut it in half, if I didn't the trike wouldn't turn it only go in a straight line. Axle runs on regular 1 inch bearings, 2 per side.
Old November 1st, 2018, 09:06 PM   #11
steven moore
I bent the first axle I had in it. The wheels stuck out too far, so I replace the axle with a new one and moved the wheels in as far as they would go. I've hit big potholes I've sent the trike in the air on two wheels ran it all over rough roads, and have never bent the axle since
Old November 3rd, 2018, 01:12 PM   #12
dcj13
Participant
dcj13's Avatar
Originally Posted by steven moore View Post
Was a solid rear axle I had to cut it in half...
So it has a single drive wheel now?
Old November 3rd, 2018, 01:18 PM   #13
steven moore
Correct, only the left wheel drives. Without a differential you cannot have two wheel drive on a street trike because the wheels will not slip enough on asphalt to turn. The only reason that old-school three-wheelers can get away with a solid rear axle and two wheel drive is because the wheels can spin over the terrain.
Old November 18th, 2018, 06:04 PM   #14
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
Sweet ride! Is this street legal? I would ride this for hours and never get tired!
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is.
Abu_Mishary is offline   Reply With Quote
Old November 18th, 2018, 06:52 PM   #15
steven moore
Yes it's streetlegal, is does require some upper body strength to maneuver though. Here's is the new wing I built , adds horsepower they say... LOL
Old November 18th, 2018, 07:47 PM   #16
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
250 ninja trike steven moore General Motorcycling Discussion 68 June 2nd, 2018 03:57 PM
Ninja 250 trike project 4950cycle Pictures 40 November 18th, 2016 01:08 PM
[motorcycle-usa.com] - Motor Trike Launches Triumph Rocket III Trike Ninjette Newsbot Motorcycling News 0 May 31st, 2014 10:10 AM
250cc Trike MrBrownTX General Motorcycling Discussion 9 May 17th, 2011 09:07 AM
Trike ninja zx12!!! Kitdog General Motorcycling Discussion 10 July 28th, 2010 01:13 PM
