Old February 6th, 2020, 08:42 AM   #1
JRay
Motorcycle(s): 2008 Ninja 250
Need help/suggestions
Good morning!
I hope that everyone is doing well!
I have a 2008 that previous owner had cut rear frame off. I am trying to do a mock up so that I can fabricate a new one and get the bike back to original.
Any suggestions or ideas on how to go about doing this would be much appreciated. I also have no clue how to calculate the exact position of the 2 cross brackets that the passenger seat snaps into.
I will try to attach photos.
Thanks in advance!
JRay is offline   Reply With Quote
Old February 6th, 2020, 09:32 AM   #2
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
i would buy the tail section of the frame, along with the tail body work and use the two to see where your cut needs to be made, to line up the tail body bolt holes with the frame
gantt is offline   Reply With Quote
Old February 6th, 2020, 09:59 AM   #3
That's what I was thinking as well.
Look for a totalled bike that rear-ended something and use the rear section. I would want to make measurements off of a non-damaged Ninja for reference. I'd also make "plugs" to put inside the tubes at the joints and bevel the joints before welding. You may need a pro to do the welding if you are not set-up to do it.
Just another case where a decent bike was hacked-up for a Bobber or Cafe Racer I would expect. Apparently no bike is safe...
Old February 8th, 2020, 04:02 AM   #4
Did you get new fender/splash-guard? It can be used to align everything.
Guy in Sac. with frame finally got back to me and said he’s got one.
Gonna pick up frame this weekend. And fender if you need it.
Last futzed with by DannoXYZ; February 8th, 2020 at 06:23 AM.
Old February 8th, 2020, 06:39 AM   #5
JRay
Thanks
Thank you for the suggestions. Danno. Can you shoot me a text when you have an approximate time cost with shipping? I have the fender now... just need the piece of frame.
Thank you!
Old February 15th, 2020, 07:57 AM   #6
JRay
Thank you
Hey guys
Thanks for the suggestions. I’m going to get the frame piece that Danno has
In the meantime I was going to make a temp bracket. Can anyone tell me the length of the rear cross bracket as well as how many inches in it starts to go vertical and then how many inches of vert before it comes across and drops back down.
If not. No biggie I can play around with it until I get it to fit properly.
Have a great weekend everybody.
Suggestions please JRay 2008 - 2012 Ninja 250R Tech Talk 8 October 1st, 2019 08:50 PM
Kickstand Suggestions LilMiss 2008 - 2012 Ninja 250R Tech Talk 6 March 24th, 2014 10:03 PM
Need some suggestions with this situation bikermunda 2008 - 2012 Ninja 250R Tech Talk 13 September 14th, 2010 06:53 AM
Boot suggestions? jeffwessel Motorcycle Gear 9 March 25th, 2009 09:57 AM
