June 28th, 2020, 04:13 PM | #1 |
Join Date: Jul 2018 Motorcycle(s): 2007 ex250 (black), silver 2005 ex250 scrambler, 2003 ex250 donor bike, 2006 kymco people 250 Posts: 73
Pregen Two brothers repack and install....
These... these are loud mufflers...
I repacked them and installed them. They sound good, throaty and deep, but they do draw attention. I also had to adjust the idle.... maybe these will work with my rejetted carb set? |
June 29th, 2020, 06:05 PM | #2 |
Two Brothers do seem to run on the loud side, on my son's cbr250 he added the silencer but it is still pretty loud though not as loud as my 250 with the single yoshi
"It ended up being the loose nut behind the wheel" |
June 29th, 2020, 07:09 PM | #3 |
I ordered the power tips for them and they are still pretty loud. I think I may check the packing and the connections after a few rides to make sure everything is ok... not going to be as popular with the neighbors as the scrambler style 250 I ride.
June 29th, 2020, 07:23 PM | #4 |
As you can tell since you repacked them they are pretty much straight through type exhaust.
June 29th, 2020, 07:31 PM | #5 |
If those Power Tips you got are aluminium, they may melt over time and cause you problems.
You'll want to get steel muffler insert with closed centre. This will force exhaust to flow through packing material and it will dampen noise quite a bit. Also improves your mid-range power on pre-gen quite nicely as well. https://www.amazon.com/dp/B075HCVJTM https://www.amazon.com/dp/B017YJ7TMQ https://www.amazon.com/dp/B07WYNV38S https://www.amazon.com/dp/B07FF1TCW6 There's quite a few designs out there. Measure your muffler's outlet and find one that fits. |
June 29th, 2020, 08:31 PM | #6 |
Thanks Danno, I will look into that. The ones I got are the ones designed for the muffler set, but, yeah they are aluminum, but the whole muffler body and end are as well, so I would hope they hold up.
They do change the sound, and I am starting to like these, but they do write a check that the 250cc’s just can’t really cash. Maybe some more tuning is in order, and I will try some inserts. What could it hurt? |
Pregen Ricor Intiminator install | choneofakind | 1986 - 2007 Ninja 250R Tech Talk | 36 | March 31st, 2016 10:11 AM |
Two brothers Pregen slip on. | dbking321 | Motorcycle-related | 10 | May 16th, 2013 04:44 PM |
Two brothers install | fredhsu | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 18th, 2012 03:37 PM |
How to install HI/Low HID bulbs into a pregen ninja | saber63 | 1986 - 2007 Ninja 250R Tech Talk | 25 | December 11th, 2011 02:16 AM |
Stock muffler Repack? | BKK1200rs | 1986 - 2007 Ninja 250R Tech Talk | 1 | June 24th, 2010 12:21 AM |
