January 9th, 2010, 01:14 AM | #1 |
Tail Light Not Working
Hi guys, can you help me trace the source of why my tail light is not working? It lights up when I press on either of the brakes but it won't stay lit when the bike is on or running. BTW, I followed this fender eliminator thread http://www.kawiforums.com/ninja-250r...tra-parts.html
January 9th, 2010, 01:51 AM | #2 |
Well, looks like I fixed it. I just unplugged the bulb and plugged it back in... then it worked. WTF??? Anyone care to explain?
January 9th, 2010, 07:11 AM | #3 |
I've had the same thing happen. No real explaination, just a fluke.
January 9th, 2010, 07:39 AM | #4 |
You are sleeping
No worries, yours is working. I just broke a rear blinker connector. Broke the little release tab. Gonna replace it with some regular crimpable bullet connectors. Maybe some shrink tube coating to keep the weather out.
January 9th, 2010, 08:34 AM | #5 |
Bike Thrasher
Join Date: Apr 2009 Motorcycle(s): 2008 EX250r Posts: 334
Keep checking it Betlog. Kawi had a problem with bulbs something to due with the filaments or something. Mine went on and off for a while. Just buy a new one and be done with it.
Intuitive Sliders, Aftermarket pegs, Custom Paint, Seat Cowl, Tinted Screen, Aftermarket flush mounts, Wheel Tape, Fender Chopped, Stock Shortie Exhaust and Woodcraft ClipOns |
January 9th, 2010, 09:36 AM | #6 |
IC2(SW)
Crimp connectors suck. Just put a small cable tie around the connector(between the wires) to hold it together......
January 9th, 2010, 03:47 PM | #7 |
You are sleeping
Yeah I was thinking one of those thin wires from inside a twist tie might do the trick too.
I'll give it a shot and see if it leaves me any intermittent wiggle in the connector. |
January 11th, 2010, 07:01 AM | #8 | |
You are sleeping
I check my lights every time I ride along with my tires and oil level. Will report how long the "Zip tie mod" holds out. I'm normally careful about that sort of thing. I was shocked when I actually broke it. I'll have to be even more careful. Probably better than crimping on a few bullets. |
Rear tail light not working. | Twitchy Stitch | 1986 - 2007 Ninja 250R Tech Talk | 2 | November 2nd, 2014 07:47 PM |
Tail light and dash light both not working | 47ninja | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 12th, 2013 05:12 PM |
brake light and signals not working :( | cuz | 2008 - 2012 Ninja 250R Tech Talk | 16 | August 28th, 2012 07:52 PM |
Tail Light + Brake Light Not Working (Bulb Replaced) | JayZE302 | 2008 - 2012 Ninja 250R Tech Talk | 11 | August 8th, 2012 05:03 PM |
LED brake/tail lights not working properly... | sktrs_kpr | 1986 - 2007 Ninja 250R Farkles | 1 | April 8th, 2010 09:59 AM |
