October 12th, 2021, 06:46 AM | #1 |
Join Date: Mar 2017 Motorcycle(s): 2013 Ninja 300 / Suzuki DR-Z 400 SM Posts: 214
How to remove glue goo left by removed tank pad?
Hello. My tank pad was peeling off a bit and was letting water and dirt come under it so I took it out.
Now I'm having a hard time to remove the glue goo that it left on the tank. I tried general purpose cleaner and alcohol. My tanks is still shiny and scratch less so I don't want to go too hard on it. Any suggestions appreciated! |
October 12th, 2021, 06:58 AM | #2 |
I use mineral spirits, AKA Varsol, AKA paint thinner. Not lacquer thinner!
October 12th, 2021, 07:13 AM | #3 |
Also try this stuff. My wife uses it to remove labels from jars she's going to re-use for other things.
https://www.amazon.com/dp/B009M14C4S/ |
October 12th, 2021, 02:31 PM | #4 |
Thanks!
October 12th, 2021, 03:17 PM | #5 |
Join Date: Oct 2021 Motorcycle(s): 2012 Ninja 250R Posts: 1
Definitely try Goo Gone!
October 18th, 2021, 02:54 PM | #6 |
Join Date: Jul 2015 Motorcycle(s): 2001 Ninja 250, 2019 Harley Ultra Classic, 2001 Suzuki SV650 Posts: A lot.
MOTM - Jan '16
Third vote for Goo Gone. Great stuff.
If using it on a painted surface wash with soap and water after the goo is removed. |
October 19th, 2021, 10:35 AM | #7 |
Join Date: Feb 2016 Motorcycle(s): ZZR250, VFR800 Posts: 478
WD40 or whatever flavour you have locally of similar stuff. Spray on agitate & it meltsvright off, no harm to your paint
January 3rd, 2022, 08:02 AM | #8 | |
Join Date: Sep 2021 Motorcycle(s): As of now, None but had bmw 100rr 2016 and the Vulcan 650s Posts: 17
January 3rd, 2022, 08:06 AM | #9 |
Let me know If it will work. I got a long scratch on the center bottom of the gas tank. Went to the garage guy he suggested not to remove it. Otherwise, while clearing it the surrounding area paint will also be affected. So, I hide it with a tank bag that I had ordered from Viking bags.
January 4th, 2022, 05:32 AM | #10 |
@TonyLambert
The goo gone worked nice. I didn't have any scratch on the tank. I only had to remove the glue from the old tank protector, which the Goo Gone did just fine and with not much effort. Yes, a nice tank protector may hide that scratch of yours, or at least most of it. Some pics, although not very good. One before removing the protector. At the top you can see the color is different because it was peeling off. Once before using the Goo Gone, and one after. I ended up with some scratches. I guess those were caused by dirt coming between the protector and the tank when it started to peel off. By the way, the protector was a One Design, in case you want to avoid the brand. I know it's a good brand, but it didn't stick well at the point where the N300 makes a little edge in the tank. That's where the peel off started. I will try a TechSpec next. |
January 4th, 2022, 06:09 AM | #11 | |
DIY: Super-Secure Gas Tank Holder (for when your tank is removed) | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 21 | June 16th, 2014 01:20 AM |
New Upgrades - Fender Eliminator, Tank Pad, Tank Overlay Stickers | bbjminardo | 2008 - 2012 Ninja 250R Farkles | 7 | March 22nd, 2013 03:51 AM |
Anyone removed left hand controls | whylee | Ninjettes At Speed | 12 | August 26th, 2012 10:43 PM |
How To: Remove Tank Pad | MotoED | General Motorcycling Discussion | 4 | March 7th, 2012 12:13 AM |
Need adhesive/glue for tank pad | davidgz | General Motorcycling Discussion | 3 | September 7th, 2010 05:55 PM |
