July 3rd, 2022, 04:36 PM | #1 |
Its not a 250,its a Ninja
Join Date: Jun 2012 Motorcycle(s): '11 CBR250R, '22 CFMOTO 300NK Posts: 278
Mystery open tube on top of engine
Thankfully, the '12 carb woes are finally behind me, just got the MOST WONKY carb I have every worked on with a ninja taking throttle. So now I am moving on to other projects, which includes this little opening I noticed. Is this normal, or do I need to connect this to something?
Last futzed with by jcgss77; July 3rd, 2022 at 07:13 PM. |
July 3rd, 2022, 09:51 PM | #2 |
Join Date: Oct 2021 Motorcycle(s): 2008 Ninja250R Posts: 48
On mine, doesn't connect to anything, just an empty hose routed to ground, for overflow or air may be!
Not a certain answer, but hopefully helps
Only a biker knows why a dog sticks his head out of a car window! Current Ride: 08 Ninja250R Location: Koala Land |
July 4th, 2022, 07:01 AM | #3 |
It does, thank you for taking a look on your bike. You just never know when you get one of these used, mine was missing both tightening bolts on the ends of the triple tree clamps, the side cover for the airbox, and the exhaust spacer for the muffler. I just don't understand people sometimes.
July 5th, 2022, 11:18 AM | #4 |
I put a breather on that pipe to catch any oil.
"It ended up being the loose nut behind the wheel" |
July 5th, 2022, 10:35 PM | #5 |
[visordown.com] - Triumph to open new factory visitor centre next month, with mystery | Ninjette Newsbot | Motorcycling News | 0 | September 12th, 2017 07:50 AM |
mystery part hanging from my engine | gary | 1986 - 2007 Ninja 250R Tech Talk | 7 | July 11th, 2015 12:07 PM |
Gas coming out of overflow tube. Engine not starting. | BearZ | 2008 - 2012 Ninja 250R Tech Talk | 11 | October 11th, 2014 07:53 PM |
[motorcycle.com] - Rich Olivers Mystery School Still Has Open Dates | Ninjette Newsbot | Motorcycling News | 0 | October 1st, 2014 11:40 AM |
Mystery Tube | HorizonXP | 2008 - 2012 Ninja 250R Tech Talk | 3 | August 28th, 2010 05:54 AM |
