July 16th, 2022, 05:04 PM | #1 |
Join Date: Jun 2022 Motorcycle(s): 2017 Triumph Trophy, 2001 Honda Valkyrie, 2007 Ninja 250, 2017 Yamaha 250X, 2018 YZ125 Posts: 18
Slight hanging idle question.
Hi Gang,
I picked up a 2007 250 with less than 3K miles. It had been sitting for a long time. I rebuilt the carbs, and the bike starts easily. It will start without choke on these warm days we have been having. When the bike is idling at 1500 rpms, and I blip it up to 3,000 or so, the idle hangs up there a bit and kind of slowly drops back down to 1,500. It feels like a delayed reaction as it returns to 1500ish. If I rev it up to 4 or 5K and let it drop back to 3Kish, it seems to come back down in a more normal fashion. Bike screams nicely when up in the higher rev range. Seems to be running fine when I do that. Any input is appreciated. Thanks All! |
July 16th, 2022, 05:37 PM | #2 |
1. Did you disassemble down to every last nut, bolt and individual component? If it can be further disassembled, do it.
2. Poked out all lateral bleed holes in carb-venturi, emulsion-tubes, pilot-jets? 3. scrubbed out all secret hidden passages with PEA-based fuel-system cleaner with brushes? http://n4mwd.blogspot.com/2013/10/se...-passages.html 4. ultrasonic soak, micro soda-blast everything? 5. replaced all rubbers: fuel-rail O-rings, float valves, mixture-screw O-rings, float-bowl seals? 6. set float-height with final wet-test to verify? 7. sync carbs after installation? Do search on here for "clean carbs ducatiman" for threads with how-tos and photos. |
July 18th, 2022, 07:25 AM | #3 |
Danno pretty much has it covered. Doing carbs right isn't quick or easy.
Many times, hanging RPMs means a vacuum leak -but it can also be just a lean condition due to improper adjustments or partially plugged carb circuits. Did you remove the idle mixture caps, idle mixture screws, clean the passages, and check that the o-rings are in good condition? Most of the time, when everything else is correct, setting the idle mixture screws to 2-turns out initially gives you a good place to start. After it's fully warm, I will adjust the screws to get the highest RPMs at idle, go about 1/8-turn out (richer), then set the idle speed to 1200 or so. Syncing the carbs is also a good idea before fine-tuning the mixture screws. |
Slight idle issue | NinjaNelly | 2008 - 2012 Ninja 250R Tech Talk | 8 | May 9th, 2020 01:55 AM |
Hanging idle and dies with throttle? | gitter | 2008 - 2012 Ninja 250R Tech Talk | 30 | November 9th, 2017 08:32 AM |
Question about idle mixture screw and low idle flux | daverdfw | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 2nd, 2016 10:36 PM |
Idle Question | THE BIG SITT | 2008 - 2012 Ninja 250R Tech Talk | 22 | October 29th, 2011 07:15 AM |
Hanging Idle | ak_907_ak | 2008 - 2012 Ninja 250R Tech Talk | 33 | June 14th, 2009 08:31 PM |
