Old December 9th, 2022, 12:00 PM   #1
SS310
Rear stands??
Recently picked up an 07 250 and wanted to get a pair of stands. I got the front figured out but I can’t find anything on rear stands. Do we have places for spools or is there another stand type that works better. Or maybe the center stand works as I think it lifts the rear wheel off the ground.
Any help is greatly appreciated :)
SS310 is offline   Reply With Quote
Old December 9th, 2022, 12:06 PM   #2
My '05's center stand doesn't quite get the rear wheel off the pavement with the rear tire I have, so I put a small piece of 1/2" plywood down for the stand to rest on. It works fine that way.
Welcome to the board, Zoi!
Old December 9th, 2022, 07:22 PM   #3
SS310
Do you just do that instead of getting a proper stand?
And thank you! Im enjoying looking through it
Old December 9th, 2022, 07:42 PM   #4
It came with a center stand which works fine. If I need the rear tire to clear the floor, is easy to grab the little piece of plywood. I'm not sure why anything else would be better.
Old December 10th, 2022, 10:41 AM   #5
All bikes should have centerstands! And should also have enough clearance so the centerstands dont drag even at full lean. But I get that there are inherent compromises in seat height, ground clearance, and advertised weight, keeping them off virtually all sportbikes and many other bikes. Be happy that your '07 comes with such a centerstand - it is quite useful.
Old December 10th, 2022, 12:09 PM   #6
MikeCL
Motorcycle(s): ‘04 EX250
The 250 doesn’t has a place for spools?
MikeCL is offline   Reply With Quote
Old December 10th, 2022, 01:02 PM   #7
The swingarms were given spool bosses for the 2008 redesign. Coincidentally, the 2008's onward don't have a centerstand.
Old December 10th, 2022, 01:23 PM   #8
MikeCL
Wow thanks for that I guess I can take those off my wish list now
Old December 13th, 2022, 04:39 PM   #9
Ceeloo Yello
Motorcycle(s): 250
I use stands like these:
Old December 21st, 2022, 09:58 AM   #10
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
You can buy rear "spool" stands that have pads rather than hooks. They simply go under the swingarm and lift it up, without any sort of engagement. That's what I used on my 500 (with centerstand, without spool bosses) before I did a swingarm swap. https://www.revzilla.com/motorcycle/...sku_id=1127303 is one example. My cheap set (they look a lot like the Venom ones) came with swappable pads and spool hooks, I'm pretty sure.
A centerstand is very handy and will work in most cases, but there are some tasks where a rear stand works better.
Front and rear stands ator Motorcycle-related 11 September 25th, 2013 09:12 AM
Front and Rear Stands jhunter 2008 - 2012 Ninja 250R Tech Talk 12 September 7th, 2012 03:47 PM
rear/front stands EngrNewf 2008 - 2012 Ninja 250R Farkles 11 May 29th, 2010 01:59 PM
