Old December 20th, 2023, 08:37 PM   #1
JayStreetfighter04
Motorcycle(s): 04 ninja 250
No airbox
Just got a decent deal on a running bike. It runs but bogs down when quickly throttling. While looking around the bike I realized there is no airbox and the air filters are directly connected to the carb with black tape around them. Is this the first thing I should replace or do I need to look elsewhere? super noob here so please be gentle.
JayStreetfighter04 is offline   Reply With Quote
Old December 21st, 2023, 07:34 AM   #2
Welcome!
Yes - you are on the right track.
Most will agree that the engine runs best with an original airbox.
In addition, it's very possible you may need to remove and clean the carbs, which requires some patience and research to do it properly the first time.
You can try installing an airbox and doing some basic tuning of the idle mixture screws, then test riding to see if the carbs need attention.
The carb type on the Ninja, a Constant Velocity (CV), doesn't like to be whacked-open quickly. They work much better with a smooth roll-on of the throttle, even when properly tuned.
Make sure the fuel is fresh, and you have a good fully charged battery, before doing any testing.
take out airbox? Japowger 2008 - 2012 Ninja 250R Tech Talk 8 October 15th, 2018 04:50 AM
Should there be a hole in the airbox? rustyshackelford 1986 - 2007 Ninja 250R Tech Talk 7 September 23rd, 2018 09:54 PM
Airbox james250ninja 1986 - 2007 Ninja 250R Tech Talk 1 February 23rd, 2017 08:02 PM
'08+ Airbox Countersteer Motorcycle-related 0 June 10th, 2012 12:50 PM
Airbox installation greenaero 1986 - 2007 Ninja 250R Tech Talk 3 March 18th, 2012 09:51 PM
