May 5th, 2010, 07:15 PM | #1 |
Join Date: Mar 2010 Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919 Posts: 605
First Impressions
Okay I am still in the break in period for another couple of commutes on the ninja and i got some impressions and questions for all the knowledgeable people here.
I got a good bit of highway commute and I have been keeping the revs no more than 10k once or twice to 11k. It seems to be running around 70mph at 9-10k. of course that depends on speedo error and all, I want to lower the rpms and regear for more cruising speed, how much of a difference will going down 1 tooth in the front drop my revs? I think I also need to get the lower clipons the stock bars seem too high. the rearsets seem to be near perfect and the seat isnt all that bad. I know everyone says the 250 has enough power but I find myself wanting more on the highway alot more, I guess I have to get used to the high rpm needed to run this bike, it seems like I am beating on it unnecessairly. My last bike was a SV650 and it would cruise at 70mph around 6k rpm so i got a learning curve.. Now on the backroads I love the ninjette it is so light and handles great even with the IRC tires, I only have 200 miles on the bike but with 90 mile commutes the miles will add up fast. I bought the bike mainly for a commuter and some backroad bombing, funny I haven't even tried to wheely the ninja on the SV I couldn't help but popping them all the time, especially power ones. Anyone got any suggestions feel free to throw em out there. |
May 5th, 2010, 07:47 PM | #2 |
Join Date: Apr 2010 Motorcycle(s): '01 Ninja 250 Posts: 6
You need to go up teeth in front to drop RPMs, if you drop teeth in front the front sprocket has to turn more to turn the wheel the same amount.
Up in front and down in back will lower RPMs for a given speed. http://faq.ninja250.org/wiki/I_want_...nge_my_gearing |
May 5th, 2010, 07:49 PM | #3 |
May 5th, 2010, 07:56 PM | #4 | |
May 5th, 2010, 08:00 PM | #5 |
Just playing with you, Michael.
I agree the wiki over on 250.org is a great resource. Just wanted to let others know that we have resources here, too, which a lot of members are unaware of and/or is rarely used. http://www.ninjette.org/wiki/Index |
May 5th, 2010, 08:11 PM | #6 |
Ok I will look into the up in front, don't really want to mess with changing chain as the bike is brand new, so going up 1 tooth in front going to make a noticable difference if not I will deal with it as stock until I feel like dropping the $$$ on 2 spockets and a new chain.
Ok checked it out i will have to order a new front sprocket and put it on. |
May 6th, 2010, 07:30 AM | #7 |
Join Date: Jan 2010 Motorcycle(s): 2005 Suzuki S50, 2006 Kawasaki Ninja EX250F, 1990 Honda PC800, 2000 Yamaha TW200 Posts: 848
This engine is designed for high rpms - the redline is 14,000. It is not comparable at all to that in the SV650, but the 6,000 rpms of the SV is pretty much equivalent to the 9,000 or so of the ninja. You may cruise at a slightly lower rpm but you may not gain any, and may sacrifice some, top end, because you run out of power against the increased wind resistance.
May 6th, 2010, 08:01 AM | #8 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
I commute on the ninjette all the time at freeway speeds. Here in utah that means my speedo is almost never lower than 80 MPH.
I haven't had any trouble with the high revs. I change my oil regularly and I run synthetic. I also check my oil level almost every time I ride. Lots of people have changed the sprockets, but I haven't; and I have had not adverse effects to date. (knock on wood). The little engine likes to be reved high. Keep it between 6k and 13k and you'll be smiling all day long.
Addicted to anything that has an engine and rolls. |
May 6th, 2010, 09:43 AM | #9 |
Join Date: Jul 2009 Motorcycle(s): '09 Ninja 250R SE (Sold) Posts: 41
Same here.
I commute on the ninjette every day and the speedo reads 90 (but i'm sure that is not the true speed ) I did up a tooth on the front sprocket, and the difference has been great. I still have great response on the throttle, and the twisties home from work each day can't be beat.
I started out with nothing & still have most of it left. |
May 6th, 2010, 09:54 AM | #10 |
I highly recommend changing the front sprocket to a 15 tooth.
May 6th, 2010, 01:19 PM | #11 |
Join Date: Mar 2010 Motorcycle(s): Blue 10 250r Posts: 697
Damn it.
"The little engine likes to be reved high. Keep it between 6k and 13k and you'll be smiling all day long." I still have another 400 miles of break-in! Arghhhh |
May 6th, 2010, 01:41 PM | #12 | |
May 6th, 2010, 02:09 PM | #13 |
Join Date: Jul 2009 Motorcycle(s): 2005 CBR600RR Posts: 132
Yea, go with the 15 tooth front sprocket. You'll loose a little off the line acceleration... but you will gain some topend on all gears.
Very good investment for 20-30$
2005 CBR600RR - 2:19 Calabogie Motorsports Park, Ontario, Canada |
May 7th, 2010, 05:23 PM | #14 |
Definitely try the 15T sprocket. As far as break in is concerned---give it hell. Kawi`s break in is pure BS. After 1000 miles, switch to synthetic. You and the bike should be fine. Incidentally, you do not need a new chain if you go for a 15T.
May 7th, 2010, 06:16 PM | #15 |
Join Date: Mar 2010 Motorcycle(s): 08 Kawasaki Ninja 250R Blue Posts: 150
I turn 30 miles round trip every day commuting and run at 60-65mph approx 7000-7500rpm. Bike pulls hard enough even in 6th gear for regular riding and for the get the bleeeep out of the way can always drop to 5th gear.
Interesting thing is on the straight aways Im getting passed by 600 and liter SS bikes but coming out of the few twisties Im riding up on their backsides.
Mmmm when gone down you have look so good you will not. |
May 7th, 2010, 07:37 PM | #16 | |
May 7th, 2010, 08:07 PM | #17 |
Join Date: Apr 2010 Motorcycle(s): 2008 650R, 2009 250R (sold) Posts: 55
I asked about the break-in and someone on here told me to "ride it like I stole it" and I haven't regretted it one bit. Bike runs like a champ.
May 8th, 2010, 07:01 PM | #18 |
Update, took the bike for its first ride in the rural backroads around my house for a hour or so and I think I will live with the stock gearing for the highway, I don't think I would like it to be geared higher with all the backroads around.
1st impressions | mikromo | General Motorcycling Discussion | 6 | September 18th, 2013 11:57 AM |
First Impressions | Archerzz | Motorcycle Gear | 1 | August 14th, 2011 01:46 PM |
First Ride on new 09' Impressions. | Dano | General Motorcycling Discussion | 3 | April 22nd, 2010 08:59 PM |
Hotbodies - First Impressions | 2WheelGuy | Ninjettes At Speed | 10 | April 17th, 2010 05:52 PM |
Old vs New-Gen - Initial impressions | Nemy | General Motorcycling Discussion | 24 | March 12th, 2009 07:17 PM |
