June 3rd, 2010, 10:47 AM | #1 |
new gen header compatibility
Has anyone tried to install a header off a new gen on a pre gen?? im wondering if this is possible to do, Im after a single sided exhaust on the bike, and slipon options are much better for new gens...
June 3rd, 2010, 11:08 AM | #2 |
Consensus is that it's far from being a direct bolt-on, so metal working/welding/fabrication skills would be needed. It would be a lot easier/cheaper to simply purchase a pregen system in the first place.
June 3rd, 2010, 12:07 PM | #3 |
what are the issues?? is it that the exhaust manifolds dont line up properly or are there issues with clearance around the engine/frame/swingarm?
June 3rd, 2010, 12:54 PM | #4 |
Join Date: May 2009 Motorcycle(s): '98 EX250, '02 EX250, '08 250r, '03 SV650, '98 GSXR750 '03 Hayabusa, '87 YSR50, '84 ZX900, +MORE Posts: A lot.
I can tell you that the new-gen header diameter is so small that the pipe will slide into a pre-gen header. It just won't work.
If you want a single exhaust just get a Muzzy.
CraigHarris.org Pacific Track Time CraigsWeb See you at 2014 MotoGP Laguna Seca! We'll be camping on Fox Hill. AFM #278 |
June 3rd, 2010, 04:43 PM | #5 |
Area P
Join Date: Dec 2008 Motorcycle(s): Too many to list Posts: 439
Exhaust is completely different from the exhaust ports all the way back to the mid-pipe. Tubing diameter, Flanges, collars, routing, fairings, mounting brackets, etc.. It's not even remotely worthwhile to do. Even doing extensive mods just to get one to fit, it does not perform well because the tubing diameter is too small and lengths are not correct (among other factors). We've tried it. That's why we have two completely different exhaust systems for Gen I & Gen II.
June 6th, 2010, 08:46 AM | #6 |
Livin' the Minimoto Life
Join Date: Mar 2009 Motorcycle(s): 2022 Honda Navi, 2018 Z-125 Pro Posts: A lot.
If you want single sided exhaust, go to a shop, and right before you get to the oil filter location, have them cut the left pipe (viewed from sitting on the bike). Then have them move it into a Y. Just don't let it get in the way of any drain plugs. That is by far the easiest and cheapest setup. You get a system and just bolt up half of it, selling the other half on EBAY. Someone always needs a new muffler after laying theirs down.
I was going to do that, but now I'm looking at a new bike, it is pretty much pointless right now.
--- My IG Page --- My FB page! --- 2022 Honda Navi && 2018 Z-125 Pro |
decat new gen header | gantt | 2008 - 2012 Ninja 250R Tech Talk | 7 | March 2nd, 2015 09:17 AM |
Does the 08-12 header fit the pre-gen? | ninja2007 | 1986 - 2007 Ninja 250R Farkles | 5 | February 20th, 2015 12:03 AM |
WTB 2:1 header for Pre-gen | ninja2007 | Items Wanted | 2 | October 10th, 2014 04:14 AM |
Pre gen Muzzy Header only | crazymadbastard | Items Wanted | 3 | June 19th, 2014 06:55 PM |
08+ exhaust header on pre gen? | nitrofreak06 | 1986 - 2007 Ninja 250R Tech Talk | 3 | April 25th, 2012 11:14 PM |
