Old July 28th, 2010, 06:21 PM   #1
remme
Motorcycle(s): '08 Ninja 250
hard time removing the sprocket cover
I'm trying to install shogun frame sliders. I'm at the step where I have to remove the sprocket cover to cut. The 3 bolts were removed along w/ the shift lever link bolt and shift shaft. The stupid cover just won't come over.. tried pulling it and using some rope to pull it. Also tried hitting it with a 'wooden mallet' but nada.
All the instructions said you should pull it off but damn it's hard... any solutions or suggestions?
remme is offline   Reply With Quote
Old July 28th, 2010, 07:12 PM   #2
remme
nevermind! It finally came off after two hours of frustration. Heard a loud 'click', which was probably the glue. Then a crapload of 'MFERRRR' got it off.
Trouble removing valve cover. Floki 2008 - 2012 Ninja 250R Tech Talk 6 January 4th, 2014 06:06 AM
DIY: Removing the Valve Cover on a Pregen n4mwd Videos 1 July 1st, 2013 05:26 PM
Removing the Valve Cover n4mwd 1986 - 2007 Ninja 250R Tech Talk 19 June 24th, 2013 08:25 PM
time to change sprocket? rousp 2008 - 2012 Ninja 250R Tech Talk 5 February 16th, 2013 09:54 AM
Need help removing front sprocket (countershaft) cb160racer 2008 - 2012 Ninja 250R Tech Talk 37 November 11th, 2012 10:53 PM
