August 10th, 2010, 06:09 PM | #1 |
7500 Maintenance Part 1 (image intensive)
So after I got back from my vacation, my oil looked a lot darker than normal and also higher. I decided to start my 7500 maintenance early (I'm a little over 7100)
oilsight.jpg I got some Mobil 1 Racing 4T full synthetic and K&N 401 filter. filter.jpg Got my bike onto its rearstand. propped.jpg BTW, is it better to have larger or smaller spools? I have some Steel Horse spools which look like large frame sliders and they don't fully "sit" into the forks of the stand. I'll take pics when I get the chance. Got my oil pan underneath the drain plug (always recycle!). pan.jpg The oil wasn't actually as dark as I thought. drip.jpg I had bought this bike when it was at 6000 miles and previous oil change was at 5500 miles. Not sure if the previous owner was the hulk, but should the washer look like this? washer.jpg I can't imagine reusing the washer. I actually went through about 4 washers and still am unsure if I torqued correctly. I have a in/lb 3/8 torque wrench and it never seemed to click for me. More pressure would just crush the washer (is it supposed to since it's called a crush washer?). I finally just ended up using a normal ratchet and tightened to the point right before the washer would deform. I rode it a few miles and placed towels underneath to check for leaks. I also could not get the oil filter off. I have a 3/8 ratchet that's only about 8 inches long, so I guess I'll invest in a longer ratchet unless someone has some other ideas. windscreen.jpg Someone stole my windscreen! J/K I decided to paint it since it looks scratched up. Bought some spray paint for about $6 from Lowe's. paint.jpg Didn't want to go the usual black look, so got a metallic silver color to match my visor (chrome silver). helmet.jpg silver.jpg I'll update a pic when it's on my bike, but I'm letting it dry til tomorrow. So I also cleaned and lubed my chain, changed my rear brake fluid, but am having trouble with my front cylinder. brake.jpg I didn't notice it when I bought the bike, but my right screw was stripped. The screw is tiny so I tried using my thinnest extractor, but ended up breaking the extractor while it was inside the screw. Anyone have any other ideas? I going to try a dremel and flathead screwdriver, but if that doesn't work I am looking for a new cylinder. I guess it'll also be my motivation to do stainless steel brake lines. That's it for today. Tomorrow I am gonna dive into the engine itself and check valves and change my spark plugs. I also have to swing my Cycle Gear and get a windshield kit since I need to replace a few grommets for the windscreen and from my fairings. Any help is appreciated, thanks again! After this, my next project is painting my fairings white and silver (love the pics from other members here!). Anyone good at photoshop that can create some designs? |
August 10th, 2010, 06:18 PM | #2 | |
August 10th, 2010, 07:12 PM | #3 |
Join Date: Sep 2009 Motorcycle(s): 09 Ninja 250R SE Posts: 376
I had the same issue getting the filter off. I bought a breaker bar from Sears. That will get the job done. Longer equals more torque. Gotta get that thing off some time.
On another note, I thought the 7500 mile service required a valve clearance check. I'd look into getting that done. |
August 10th, 2010, 07:32 PM | #4 |
Yup, checking valves tomorrow. I'll try using a thicker extractor and hopefully it works.
August 10th, 2010, 08:26 PM | #5 |
Great pics. I use Mobile 1 racing 4T as well, great oil.
I can't wait to see the painted windscreen installed. That will be a very unique look. |
August 10th, 2010, 08:38 PM | #6 |
Join Date: Nov 2009 Motorcycle(s): 300, WeeStrom Posts: A lot.
If you haven't already bought the windshield, there's a site, I think it's called new Enough or Nu-enough...I priced a few parts there and they were very reasonable. I'm sure someone else on the site has their correct name.
August 10th, 2010, 08:42 PM | #7 |
Duh ? Didn't get the J/K....well, glad to see no one stole your windshield. Being from NY...they'd take the air from your tires here.
August 10th, 2010, 08:46 PM | #8 |
Join Date: Mar 2010 Motorcycle(s): 2010 Ninja 250R (sold), 2012 Tuono V4R Posts: 512
Yeah, the idiot before you definitely overtightened that washer.
2010 Kawasaki Ninja 250R - "Aria" (sold) 2012 Aprilia Tuono V4R - "Perrine" Proof that Harleys and Ninjettes are friendly with each other |
August 10th, 2010, 09:02 PM | #9 |
Yea, grew up in NYC as well. Had 7 different breakins in my car (and I was driving a galant then!). Insurance was crazy high there for me too.
August 11th, 2010, 11:49 AM | #10 |
Part 1 1/2
So today I went out a bought a 1/2 in drive breaker bar for my oil filter bolt. I'm not sure if I'm really weak, but still could not get that sucker off! I also managed to have the bike fall on me
Luckily the bike is fairly light and I was somehow able to catch it. The left spool was still attached to the rearstand so it was awkward trying to get the bike back onto the kickstand (had to kick the rearstand to it's side). I finally gave up and brought it to a local scooter shop near me. I just had some Pho (awesome Vietnamese dish) and am now laying on some grass wondering why I like to do things myself Here's a pic of the windscreen on. Paint came out nice and dried quickly. Not a huge fan of it yet, but I am planning on painting (probably myself) the bike white, silver and black so it'll match better. |
August 11th, 2010, 12:03 PM | #11 |
After seeing that crush washer, I wouldn't be surprised you would have trouble with the bolt; the previous owner probably overtorqued that one as well.
Are you still going to do your valves yourself? If you are, there's a thread where people are listing what clearances they're getting. (I just can't remember what it is right off the top of my head.)
August 11th, 2010, 12:06 PM | #12 | |
August 11th, 2010, 12:18 PM | #13 |
You get the screw out of the brake reservior yet?
I'm thinking you can remove the other screw and then the cap. Once the cap is off I think there will be enough of that stripped screw showing to grap with a pair of needle-nose or other set of pliers. Good luck!
August 11th, 2010, 12:42 PM | #14 |
That's weird about the screws. One of my screws on the brake reservior was partially stripped as well I thought "Oh, great" because I noticed it right when I was just about to install my SS lines (literally, had all my tools/parts laid out already). Somehow, I unscrewed the sucker and was able to install my SS lines. I then ordered another screw from the stealer ($2 ).
August 11th, 2010, 12:47 PM | #15 | |
August 19th, 2010, 05:48 PM | #16 |
Part 2
So I finally got to finish my 7500 mile maintenance and was it a pain! I had access to my friend's garage since it's a lot of work. The painful part is removing the cylinder head cover. I had saved valves for last so I flushed and replaced my coolant just to have to drain it again to do the valves
Also as a FYI, when you're looking for the 2|T through the alternator cover, it's on the black metal part lightly engraved. It took me forever to find it (for the first timing, I just matched up the cams since I just thought my bike didn't have the markings). My bike undressing My bike naked My spark plugs came out really light tan which surprised me since I thought I was running rich. I didn't do the WOT and chop though so not sure how accurate it'll be. All my valves were within spec so I am good for another 7500 miles I fully appreciate the DIYers here since it's so time consuming to take pics (esp with dirty hands!). My clipons and compass/clock/temp just arrived today so I'll take pics when I finish those. |
July 12th, 2011, 11:40 AM | #17 |
Join Date: Jun 2011 Motorcycle(s): 2008 Ninja 250r Posts: 62
July 12th, 2011, 11:47 AM | #18 |
I got the clock for $12 at walmart (do they have walmart in Canada?). If not, amazon.com also sells it.
http://www.walmart.com/ip/Bell-Sport...i_sku=14324183 Clipons are by Woodcraft. |
July 12th, 2011, 11:50 AM | #19 |
LOL - yup, we have walmart.. just it's in the shape of an igloo.. j/k
Looks awesome, what'd you use to mount it? |
July 12th, 2011, 11:53 AM | #20 |
Haha, I think of igloos when I hear Alaska. For Canada, I think of moose
July 13th, 2011, 03:35 PM | #21 |
lol, we either get one or the other :P
www.ridingjezebel.com - my resource site for new, short and female riders! my mods |
[superbikeplanet.com] - Soup Random Image Servermatron Thing (click on image to refre | Ninjette Newsbot | Motorcycling News | 0 | January 21st, 2015 04:21 PM |
LED headlight strips (Warning: Picture Intensive) | Live2ride | 2008 - 2012 Ninja 250R Farkles | 12 | November 9th, 2011 06:00 AM |
Bike accidents hurt. (Pic intensive) | Linuss | !%@*#$%!)@#&!%@ I crashed! | 22 | May 14th, 2011 12:51 AM |
[visordown.com] - Intensive care biker handed crash bill | Ninjette Newsbot | Motorcycling News | 0 | September 24th, 2009 09:00 AM |
7500 mile maintenance! | ahskeetz | 2008 - 2012 Ninja 250R Tech Talk | 11 | April 11th, 2009 05:21 PM |
