January 22nd, 2011, 08:56 PM | #1 |
Stock Rear Axle Nut Wrench + Extension
So, has anyone here actually used the above combo to successfully loosened the rear axle nut without damage to the nut?
I ask because I am planning a somewhat long trip and those two tools are easier to carry than a 1/2" drive 15" breaker bar which is what I normally use to do chain adjustments. Any recommendations for any other easy to carry tool/method to do this are also welcome. |
January 22nd, 2011, 09:03 PM | #2 |
I've never used the stock wrench on the 250R, but for dirt bikes, I carry light wrenches that fit the axle nut and stand on the wrench to break the nut loose. Try it and see if that method will work on the Ninja.
I can't see carrying around a breaker bar and appropriate socket. |
January 22nd, 2011, 09:43 PM | #3 |
I've used it a few times, just to see how well it works, and it does the job just fine. To apply force, I just kick it with my heel and it loosens right up! I have never used the extension, and in fact didn't even realize it was an extension until a good bit later, and then only ever used it when adjusting the rear shock. Anyways, the fit was surprisingly tight for a cheap stamped wrench, and it has a mildly beefy construction (for a cheap stamped wrench), so I wouldn't be concerned about it not doing what you need it do. Of course, when doing that stuff I do typically use an actual socket and breaker bar, but it doesn't hurt to know your options!
But, in general, I can do (and have done) most typical work on my bike with the tools I keep in the trunk. I made a larger canvas bag to hold a few extra tools like a real screwdriver, a 1/4" socket driver, a 19mm wrench (for lowering the bike for my GF), and a small pouch with bits and allen keys and such. The rest of the tools are the stock ones, and they actually work surprisingly well, and I give kudos to Kawasaki for including an actual workable tool kit with the bike!
Factory Pro Jet Kit, K&N R-0990 Pod Filter, Sportisi VR Black Exhaust, BRT TIS Ignition, White Paint, and 16/41 Sprockets. Soon: Maybe a 37T Rear Sprocket if I get things running like I'd hoped. |
January 23rd, 2011, 11:17 AM | #4 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250 (sold) Posts: 755
I wish I would have known that I had that wrench before I used a pair of pliers to loosen my rear axle bolt. Lol, I need more tools.
The Ninjette is not a disposable bike. You are not ever supposed to get rid of it. It is like a [friendly] herpes virus.... once you got it, you get keep it forever. Originally posted by-Headshrink |
January 23rd, 2011, 01:47 PM | #5 |
Join Date: Dec 2008 Motorcycle(s): '08 Ninja 250, '11 Street Triple R Posts: 337
How long of a trip? Do you really need to adjust the chain before you get back?
The Sunday Best | Current mileage: 50,000 |
January 23rd, 2011, 02:25 PM | #6 |
6000 km one way
January 23rd, 2011, 02:32 PM | #7 |
I think I might just get a 3/8 to 1/2 drive adapter and use a pipe over my 10 inch breaker bar to do the same. Or somehow strap the 15" bar to the frame.
January 23rd, 2011, 02:35 PM | #8 |
Or a pair of 10" Knipex cobra pliers. I know some of you don't like using them, but they're awesome. I have a 7" pair. That way I can toss away the breaker bar and the 22/24mm sockets. Lighter too.
January 23rd, 2011, 02:57 PM | #9 |
My axle and chain got inexplicably tight and I couldn't loosen it without it lifting the bike off the stand (axle inserted from the right; could not push down on opposite side due to passenger peg in the way). I even added the shock preload adjustment spanner wrench in the other side for extra leverage and it took me about two hours to loosen it with the tools I had.
Front Axle Castle Nut | JLinde1339 | 1986 - 2007 Ninja 250R Tech Talk | 8 | December 9th, 2011 01:23 PM |
Hitch Pin for rear Axle nut? | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 3 | July 6th, 2009 08:30 AM |
axle nut torque? | nate-bama | 1986 - 2007 Ninja 250R Tech Talk | 10 | July 3rd, 2009 08:22 AM |
Rear Axle Nut | Rawr | 2008 - 2012 Ninja 250R Tech Talk | 16 | May 22nd, 2009 08:40 AM |
Front Axle Nut | Flashmonkey | 1986 - 2007 Ninja 250R Tech Talk | 6 | May 9th, 2009 10:57 PM |
