February 1st, 2011, 08:36 PM | #1 |
Complete toolkit
So, I'm putting together a toolkit with tools of better quality than those that come with the bike.
1) I want to know all the type and sizes of fasteners used on the bike. So far, I've got these taken care of: Hex bolts/nuts: 6mm 8mm 10mm 12mm 14mm 17mm 22mm 24mm Allan: 4mm 5mm 6mm Philips: ?!?!? 2) What size is the front sprocket nut? 3) I tossed away the screwdriver that came with my stock toolkit. Anyone know if the combo was Philips 1 & 2, or 2 & 3? 4) I've read of people stripping their carb screws because they require a JIS bit. What size is needed for carb work? And is this the only place where JIS bits are needed? 5) Is the chain adjustment (lock and adjuster nuts) the only maintenance item that requires open ended wrenches? 6) Is there a torque adapter like this one that would cover the whole torque range required when working on the bike? 7) Who here always uses a torque wrench/ratchet/adapter here anyways? I always go by feel. 8) Would a 1/4" drive ratchet/flex head suffice for all work required on the bike (excluding axle bolts and front sprocket)? Or would I be better off with a 3/8" drive? 9) Is there any place on the bike a sliding t-handle with a 6" extension can't reach? PS: I'm looking for portability and trying to eliminate redundancy for an upcoming trip. Will post more questions. |
February 3rd, 2011, 10:02 PM | #2 | |||
QuarterLiter Affectionado
Join Date: Jan 2011 Motorcycle(s): 2010 Ninja 250R , 2009 Yamaha FZ6 Fazer Posts: 20
The other items I really don't know, but others will chime in. Good Luck on your Trip.
K&N 0990, FP Jet Kit, Yoshimura Full System, Kleen Air Removed, Kisan Modulators Front and Rear |
February 6th, 2011, 09:08 AM | #3 |
Thanks.
What is the size/number of the JIS screwdriver on the OEM toolkit? |
February 6th, 2011, 03:02 PM | #4 | |
These people have been a good source for me, plus Sears. http://www.boltdepot.com/socket-products.aspx
March 15th, 2012, 09:03 AM | #5 |
I came across this thread looking for the sprocket nut size (I think it's 24mm Edit: Nope. 27mm; looks like 24mm is the rear axle nut) and saw discussion about the screwdrivers included in the kit being "JIS." I kinda doubt it. Here's why:
They don't seem to fit anything on the bike. The big one will not fit the large side cover bolts, which has really frustrated me when I needed it (note: same bolts as found on the battery box). The little one will not fit the front brake fluid reservoir. Another indicator that they weren't made for the bike is that it includes a flathead when there aren't any such screws on the bike. It's too big to use to retract the CCT pusharm too (takes a tiny flathead). That said, there is a little screw on the undertail that holds the wire to the rear brake light switch that the smaller cross driver may be able to turn (still doesn't fit well). My understanding is that JIS bits/drivers will fit JIS screws/bolts VERY well. |
March 16th, 2012, 04:15 AM | #6 | |
http://www.ninjette.org/forums/showt...&highlight=JIS |
March 16th, 2012, 05:25 AM | #7 | |
A parts catalog is his real friend: 92107A TOOL-DRIVER,#3PHILLIPS 92107-0010 92107 TOOL-DRIVER,#2PHILLIPS 92107-0009 As I said before, the included tools are either NOT JIS or they are labeled wrong. As you see, they are labeled as "Phillips," but a real #3 Phillips fits the side panels perfectly when this does not. No matter what, I cannot find a scenario that perfectly explains a real #3 Phillips driver fitting the supposedly-JIS bolts well, while the so-called "#3 Phillips" included with the bike does not. Either people are wrong about there being no Phillips screws on the bike AND the parts catalog is wrong about what kind of driver it is or we have two fundamentally incompatible #3 Phillips drivers despite the standardization and we are still left wondering why it didn't include JIS drivers for a bike with exclusively JIS bolts. |
March 16th, 2012, 09:34 PM | #8 |
For those looking for a decent set of JIS drivers: http://www.ikaswebshop.com/hojisscset5d.html
JIS +0 and +1 have taken care of pretty much all + bolts on the bike so far. I haven't gone after the carbs yet but I think they take +0. |
March 16th, 2012, 09:52 PM | #9 | |
SOLD MY NINJETTE and got THIS |
March 16th, 2012, 10:32 PM | #10 |
Do they fit in the handle? Mine fall right out. If they really are supposed to be Phillips and they fit well just like a provided Phillips (when I use my own Phillips #3, for example), I assume that they really are Phillips bolts and not JIS. Having the wrong driver shaft may explain a few things. Perhaps my shaft is JIS even though the parts catalog says I am supposed to have a Phillips? I don't see anything obviously wrong with mine, but it can't even turn a loosely tightened Phillips #3 bolt. For example, using my own Phillips #3 driver, I can tighten down the side panel with less force than I would ever be comfortable with on the road and yet the included driver cannot loosen it. No matter how much downward force I use, it slips.
March 16th, 2012, 10:34 PM | #11 |
That, they don't. The fit is very loose. There isn't much play but they definitely don't stay in very well.
Building a Toolkit! | TBC | 1986 - 2007 Ninja 250R Tech Talk | 36 | May 30th, 2013 10:05 AM |
Toolkit that comes with bike? | Advincula | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 31st, 2012 06:46 PM |
Toolkit wanted | dcmidnight | Items Wanted | 5 | October 8th, 2011 11:37 AM |
