February 2nd, 2011, 12:34 PM | #1 |
Mr. 988
Grip Warmer power source.
I have grip warmers to install and was thinking of installing a relay vs, using the axillary wires so they will turn off when the bike is shut down. However, it dawned on me that the license plate light wire is not being used as I removed my rear fender and the tail light now lights the plate.
Anyone used this power source for grip heaters?
"I'm the one that's got to die when it's time for me to die, so let me live my life, the way I want to" - Jimi Hendrix Cancer |
February 2nd, 2011, 12:37 PM | #2 | |
Join Date: Apr 2010 Motorcycle(s): 2009 Honda CBR600RR Posts: 633
On a side note I was pulled over for using my brake light as a light for my plate. Popo told me that it wouldn't fly and it wasn't properly lit. I guess he thought it wasn't enough light to make it readable.
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja |
February 2nd, 2011, 12:41 PM | #3 |
Mr. 988
Yep, have the High-Off-Low switch.
Never had a problem with my brake light / plate light combo. Passes inspection all the time. YMMV. I do not think that the long wire run will cause issues. However, I may be wrong.
February 2nd, 2011, 12:59 PM | #4 | |
Edit: Here's that wire (white one with the white plug on it) I'd say if the wire is about the same gauge on the grips then you should be ok. Sorry just noticed yours is a 05 so it may not look exactly the same.
February 2nd, 2011, 01:44 PM | #5 |
Mr. 988
Thanks Nate. Trying to keep it switched vs. hot as I am old and will forget to switch the grips off.
February 2nd, 2011, 02:20 PM | #6 |
Keep the relay and use the light circuit to power it. Seems the simplest/safest approach. How many watts do your grip heaters draw?
February 2nd, 2011, 03:59 PM | #7 |
I just recently installed mine (symtec's with the black button switch hi/off/low) and the relay's are nice because they can be used for other things later if you choose. I used the horn circuit to trigger the relay. I found it easier to use a relay because it has ground as well. Otherwise you'll need to figure out where you want to wire ground to the frame.
Are you installing heated grips themselves or the heating elements under your stock grips? If you choose to use the heating elements, I suggest wrapping the clutch side with one layer of electrical tape for insulation and then on top of the elements, wrap it in aluminum "duct" tape. This keeps the elements in place and protected with the added benefit that the aluminum is kind of like a heatsink. Hope that makes sense. |
February 2nd, 2011, 11:24 PM | #8 |
Mr. 988
Brian, I have the heating elements that go under the grips. I am concerned now about using the tail light circuit. Checking the wiring diagram for the bike, all the turn signals and brake light use the same fuse.
Thanks for the tape tip.
February 3rd, 2011, 01:17 AM | #9 | |
More importantly, you'll never need to worry about messing with the bike's dedicated circuitry. Especially, since blowing the tail light is a fairly large risk for hand warmers. Now if you were installing deflector shields then who cares about the tail light. |
Warmer weather is almost here... | reaubideux | The Ex-Ninjetters Lair | 13 | March 15th, 2015 10:02 PM |
Pro Grip 724 Dual Density Road Grip | fmx | 2008 - 2012 Ninja 250R Farkles | 10 | May 5th, 2013 07:47 PM |
Rear tire warmer size? | abhijitz | Ninjettes At Speed | 5 | December 29th, 2011 06:02 AM |
How To: DIY 12v Power Source | ChaosFromAbove | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 27th, 2011 07:00 AM |
What to do while waiting for warmer weather | GreezMunky | Off-Topic | 5 | February 28th, 2009 04:45 PM |
