March 6th, 2011, 10:00 PM | #1 |
Join Date: Feb 2011 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 15
Bolt/Nut Discoloration
Hey All,
This may be nitpicking, but the stem nut(i think that is what it is called) and handle bar bolts look like they are discoloring. I am not sure what it is from. It might be the black coating coming off? Not sure. I am also getting some rusting on the muffler but I plan on swapping that out soon so I am not that concerned about it. My question is whether I should have the dealer replace these items under warranty? My fear is that in a couple of months they will start rusting. Furthermore, I also fear that after the warranty expires I will still have the same problem. Are there after markets parts that I should look at? I did find this for a stem nut replacement. I have attached some pictures. |
March 6th, 2011, 10:05 PM | #2 |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
OCD kicking again? Lol I don't think those parts will be covered. Seems like the paint is easy to "rub" off. Mine have the same problem also. You may have to replace them out of pocket, and I am sure they have aftermarket bolts for that center nut. I have seen 250's with multi color ones on their bikes, (red, blue, ect)
March 6th, 2011, 10:07 PM | #3 |
So, where's the reverse?
As long as your nuts aren't blue, everything is good
March 6th, 2011, 10:29 PM | #4 |
Normal wear and tear. Highly unlikely to be covered under warranty.
March 6th, 2011, 11:34 PM | #5 |
March 7th, 2011, 03:45 AM | #6 |
User Title Free Since '12
Join Date: Dec 2010 Motorcycle(s): '10 Ninja 250R Special Edition Green Posts: A lot.
MOTM - Feb '12
Mine is also a bit beat up there. The paint is thin and comes off pretty easily when my keychain or other keys rubs on it. Best way to solve the issue is probably to use only your Ninjette key, off of a keychain and away from other keys, when you ride.
"Improvement makes straight roads, but the crooked roads without improvement, are roads of genius." — William Blake |
March 7th, 2011, 06:57 AM | #7 |
Livin' the Minimoto Life
Join Date: Mar 2009 Motorcycle(s): 2022 Honda Navi, 2018 Z-125 Pro Posts: A lot.
I was going to rattle-can my triple, but I just never got around to it. I was also thinking, since that is exposed so heavily to the sun, to take it apart and send it out for powder coat. Of course that never happened either. I used touch up paint from my Dark Shadow Gray Mustang GT. It wasn't perfect, but it looked better than seeing scratches.
--- My IG Page --- My FB page! --- 2022 Honda Navi && 2018 Z-125 Pro |
March 8th, 2011, 12:22 AM | #8 |
My bar ends are almost silver now.
March 8th, 2011, 03:47 AM | #9 |
MOTM - Feb '12
Good forum discussion linked about nut discoloration.
March 8th, 2011, 05:01 AM | #10 |
Hey!!! Why does this ad pop up when I click on your link???
...and what is she looking at??? |
March 8th, 2011, 06:13 AM | #11 |
Join Date: Jul 2010 Motorcycle(s): Honda, Buell, Kawasaki, Suzuki, Yamaha Posts: 170
Can you not get cover caps for those Allen bolts. Previous generations had them. As for the stem bolt, take it out and rattle can it with engine ceramic paint. You may have too many keys rubbing on it.
March 8th, 2011, 06:19 AM | #12 |
Everything can be painted. Bolts can be taken out, cleaned and painted black and silver bolts painted with clear. Color rite has paint for the frame. http://www.colorrite.com/product/kaw...black-2179.cfm
March 8th, 2011, 06:56 AM | #13 |
Just put this in the ignition
And use this to attach it to your main keyring. Less scratches on the triple if you do that...
March 8th, 2011, 06:58 AM | #14 |
Join Date: Apr 2010 Motorcycle(s): 2009 Honda CBR600RR Posts: 633
I think that banner is only set to show for you .. maybe someone is trying to say something jk
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja |
March 8th, 2011, 07:30 AM | #15 | |
Edit: That same pop up keeps comming up for me too! Lol
Can't remove Clutch pivot bolt lock nut! | ninja98r | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 22nd, 2013 04:52 AM |
DanMoto JISU Discoloration Fix | cmSAE | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 16th, 2013 03:20 PM |
clutch lever pivot bolt/nut torque specs | Confuzshuz | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 25th, 2012 05:11 AM |
Clutch pivot bolt and nut | setasai | Items Wanted | 4 | October 8th, 2011 08:14 AM |
Never use fuel tank linear, and there is a nut on the clutch lever bolt... | saber63 | 1986 - 2007 Ninja 250R Tech Talk | 0 | April 23rd, 2010 08:58 AM |
