March 20th, 2011, 04:00 PM | #1 |
Bike lacking power on commute today.
This is my regular commute and I have noticed that the bike has more power on some days and less on others, which I believed to be temperature-related, but it's never been this bad and it isn't even really that cold.
Basically, my commute is almost all freeway driving and I usually hit 80-90 indicated easily (I often see it indicate 100-107... SHHH!). This time I could barely go past 70. It took a long time, but I did get to 75 on a flat area and 80+ going downhill. I usually get a lot of speed in anticipation of a steep incline for the last leg of my commute but I just couldn't do it and my speed dropped into the 50s on a 65MPH stretch. My handling also felt a little weird. Scary actually. It's a cool (not cold) windy day and it felt like I couldn't counteract the wind... as if my rear tire were flat and affecting my ability to lean. Maybe I imagined it, but it felt like I was sitting closer to the ground too! I think I need to check my rear shock when I get the chance (just arrived at work; still at my desk). There will be rain on the commute home tonight and when I return in the morning (yes, I only get 8hrs off between these shifts), so that's really concerning me. I have had a slow coolant leak that wasn't a problem last I checked (many months to reach the "low" mark and just filled back a week ago) and I'm way over-due for my valve check. So I can rule it out or in, what does an engine feel like after the valves are damaged or the coolant suddenly leaks out? |
March 20th, 2011, 10:24 PM | #2 |
Rear shock seems fine (compresses when I put weight on it and bounces back). Tire pressure feels fine (I'll see if I can find a gauge). Can't see the water level and can't check without taking the fairings off (typical and something I can't do at work). My break's over and I can't check much else until it's time to go home.
March 20th, 2011, 11:44 PM | #3 |
Seems like a rash of power shortage/fussy behavior being reported; fair chance it's at least a little weather related. Would definitely check tire pressure when ya can; I definitely feel the ride get a little 'soggy' if I'm a few PSI under usual. Might have an ethanol-fouled main (or other) jet.
Haven't fubar'd valves (I think) so no direct-experience help there, but I think it'd be pretty significant. But in theory if your valves are far enough off it would definitely result in a performance change as the engine has too much or too little time to do what it should be doing (in-flow of fuel/air or exhausting). I wouldn't rule it out, but obviously easier to check the easy (or at least easier) stuff first. I'd wager a significant coolant shortage would yield a seized engine, likely while in motion or immediately after a ride.
March 21st, 2011, 03:51 AM | #4 | |
Go Pack Go!
Join Date: Feb 2011 Motorcycle(s): 09 250R, 07 XL1200L Posts: 39
As for the mechanical side, one thing you did not mention was the exhaust leak. I have had loss of power from it before. But that doesn't make your handling "weird". The valve problem shouldn't give you handling problem either.
09 Ninja 250R (commuter) 07 XL1200L (weekend fun) 02 SV650S (totaled by an idiot cager) & others |
March 21st, 2011, 09:13 AM | #5 |
I found that wind, hills and temperature can have a profound affect on how the ninja handles and performs. Wind is the worst.
March 22nd, 2011, 10:28 AM | #6 | ||
I could've sworn that I updated the thread that night to say that it felt fine on the way home. It also felt fine on the way back (yes, 8hrs between shift) and on the way home again. The wind had died down but I got rained on significantly during all three later trips. Someone died on their motorcycle on SD freeways yesterday morning, so I probably should've taken a bus!
It did remind me of the day I crossed New Mexico and Arizona with a headwind (I had to draft large vehicles to maintain 55MPH). |
March 22nd, 2011, 01:24 PM | #7 |
‘94 Rider
Join Date: Nov 2010 Motorcycle(s): 1994 Kawasaki Ninja EX250F Posts: 81
You will definately want to check/adjust your valve clearances as soon as possible. At N250RC they say time and time again all the weird and possibly damaging things that valves (out of adjustment) can cause. They will melt if severely neglected.
March 22nd, 2011, 01:33 PM | #8 |
I've been saving up for months but crap keeps happening.
March 23rd, 2011, 10:42 AM | #9 | |
Go Pack Go!
RIP rider...
[motorcyclenews.com - news] - Why don't you commute by bike? | Ninjette Newsbot | Motorcycling News | 0 | March 5th, 2014 08:50 AM |
Bike stalling at lights on morning commute. | agentbad | 1986 - 2007 Ninja 250R Tech Talk | 20 | December 6th, 2013 02:05 PM |
Commute from NJ to NY with bike?? | fr1dayn1ght | General Motorcycling Discussion | 6 | September 30th, 2013 09:47 AM |
My commute today | Chuffmonkey | Ride Reports | 28 | July 14th, 2012 08:51 AM |
How was your morning commute today? | Apex | General Motorcycling Discussion | 23 | November 11th, 2010 02:00 PM |
