May 1st, 2011, 07:12 PM | #1 |
Coolant in oil - a frothy mess!
I'm not worried about how it happened, I know how it happened (accidentally spilled it with the valve cover off). I just changed the oil, but I still have a soapy/frothy mess on the inside of the engines. How big a deal is this? I'm hoping it will burn odd, but I'm concerned the residue might clog the oil jets... Now what?
May 1st, 2011, 07:30 PM | #2 |
buy a gallon jug of conventional supertech 10-40 (non ec) oil at walmart. ride the bike till it's nice and hot, then change the oil. if it still appears to be milky after the oil change, ride it a few times, then change it again. Oil should appear good at that point in the sight glass. I've gotten water in the crankcase of my dirt bikes before and it takes at least 2 flushes to get all of the water out of the crankcase.
After the oil is back to normal looking, do an oil and filter change to what you normally use. |
May 1st, 2011, 08:02 PM | #3 |
Awe, and I just used the $$ stuff.... I'll pick some if that up. Will this cause any damage if it isn't taken care of asap?
May 1st, 2011, 08:26 PM | #4 |
I wouldn't leave it in and try to save money, if that's what you're asking. water will break down the oil and diminish it's ability to lubricate properly.
just think of it as a cheap solution to your screw up. it could have been a lot wor$e. |
May 1st, 2011, 09:07 PM | #5 |
I wasn't thinking of leaving it... just using it to go to work.
It was a small amount that got it, but the foaming reaction sure was dramatic.
May 2nd, 2011, 08:40 AM | #6 |
ModMy250.com
The foaming reaction can cause bearings to spin, which will destroy your motor. The coolant will change the viscosity of the oil. <--Just like Kelly said.
The www.ModMy250.com guy |
Attempting to change oil, huge accident happened with coolant. Kinda important. | Insane Pie | 2008 - 2012 Ninja 250R Tech Talk | 15 | December 3rd, 2014 03:30 PM |
Oil and coolant leak | SwagenGTI | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 16th, 2014 11:49 PM |
2008 Coolant in Oil? | First bike! Need some suggestions | champofgames | 2008 - 2012 Ninja 250R Tech Talk | 9 | October 30th, 2014 12:38 AM |
Coolant in my Oil.. what the flip?? | prettypistol | 2008 - 2012 Ninja 250R Tech Talk | 20 | March 25th, 2012 04:14 PM |
Oil level, suddenly too high; coolant too low | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 6th, 2010 11:18 AM |
