May 19th, 2011, 09:07 PM | #1 |
Join Date: Mar 2011 Motorcycle(s): 09 ninja 250r Posts: 97
tach bouncing when wot in 2nd.
Started this today. I had to change lanes fast and went WOT for the rest of secound. I noticed the tach bouncing. So tested it a few more times, did it everytime but only on secound at WOT. Anyone have a idea?
May 19th, 2011, 09:11 PM | #2 |
Join Date: Aug 2010 Motorcycle(s): 2007 ninja ex500, 2010 Ninja 250r, 2004 zzr600, 2003 CBR600rr, 2013 Ninja 300...in that order :D Posts: 266
are you hitting redline on your tachometer in each gear?
May 19th, 2011, 09:18 PM | #3 |
you're hitting the rev limiter... it prevents you from over revving the engine. shift!!!
May 19th, 2011, 09:43 PM | #4 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
i found that after i put on the louder exhaust from AP, that i hit the limiter less, since i was more conscious of the noise i make revving the bike all the way till the limiter, lolz...
there are a couple solutions, easiest, is to shift sooner as kkim said, but you could also change the CDI to the BRT, and raise the limit by another 500~ rpm, that helps. or get a Koso speedo that has a shift light :P
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
May 19th, 2011, 10:57 PM | #5 |
Hmm, ok thanks. Didnt think i was that close to it but was also tring to not get hit.
bikes throttle sputters at WOT | ninjamatt03 | 1986 - 2007 Ninja 250R Tech Talk | 11 | September 16th, 2014 07:37 PM |
Gas tank whine or not...at WOT | Redsvt | 2008 - 2012 Ninja 250R Tech Talk | 17 | November 15th, 2012 07:05 AM |
Light WOT Hesitation? | JMcDonald | 2008 - 2012 Ninja 250R Tech Talk | 24 | September 16th, 2010 05:41 PM |
Something seems unbalanced... Tach needle bouncing | Avaholic88 | 2008 - 2012 Ninja 250R Tech Talk | 26 | July 12th, 2010 12:27 PM |
WOT - easy question | headshrink | General Motorcycling Discussion | 15 | April 23rd, 2010 01:37 PM |
