June 8th, 2011, 12:52 PM | #1 |
Always.
Join Date: Mar 2011 Motorcycle(s): '08 Ninja 250, '05 GSX-R600 Posts: A lot.
Painting rims...?!
I just wanted to get some info about "powder coating" what is this?
Do people get shops to paint there rims or is there an easy DIY way? Would you have to tape off the surrounding area or take the rims off? |
June 8th, 2011, 12:58 PM | #2 |
Powdercoating involves completely stripping it to bare metal, electrostatically applying a thin coat of plastic powder, then melting it in a special oven at around 450°F to fuse the plastic to the metal. All bearings and parts have to be removed because of the curing heat. Threaded holes are plugged with special high-temperature silicone plugs and tape.
Powdercoat will not stick to paint, old powdercoat, etc. Anything that melts or is damage by heat can't be powdercoated. Most of the cost of powdercoating is the labor to strip the old finish off. |
June 8th, 2011, 01:00 PM | #3 |
Join Date: Dec 2008 Motorcycle(s): 2008 250r(sold). 2013 Kymco Super8 150 Posts: 223
June 8th, 2011, 01:47 PM | #4 |
A cheaper and easier way of adding color to your rims is by painting them yourself using the rattle can method. Here is a thread on how I did mine. http://www.ninjette.org/forums/showthread.php?t=45757
June 8th, 2011, 05:06 PM | #5 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
HIGHLY recc. pcing if you want to customize your wheels. the finish is flawless, and very, very durable (no damage during tire changes). yes, it costs more than a rattle can job, but the results are well worth it in my opinion.
June 8th, 2011, 05:18 PM | #6 |
How much should powdercoating a set of wheels cost, and how would you go about sourcing a reputable shop to do it?
June 9th, 2011, 04:12 PM | #7 |
Ninjette CPT
duborjr1 helped me with mine. the wheels have to be completely disassembled (remove bearings, cush drive, etc). got mine done for $200.
FS: VRossi Rims | DJK | Motorcycle-related | 6 | July 18th, 2013 08:16 PM |
Powdercoated Rims | forevertwowheels | Pictures | 23 | September 25th, 2011 08:41 PM |
Rims... | LittleNinja | Items Wanted | 0 | March 27th, 2010 03:04 PM |
bigger rims | NoobNinja | General Motorcycling Discussion | 9 | September 2nd, 2009 07:59 AM |
Rims | tjkamper | 1986 - 2007 Ninja 250R Farkles | 1 | April 24th, 2009 02:43 PM |
