June 20th, 2011, 11:41 AM | #1 |
Join Date: Apr 2011 Motorcycle(s): '09 250R, '13 CBR500R Posts: 709
visually syncing carbs
I am getting ready to do some major work on the bike: full exhaust, air box removal, k&n filter, and FP jet kit. I read somewhere in one of Vex’s DIY carb sync with the bottles, somebody replied that you can “visually” sync the carbs while you have them off. I’ve never worked on carbs before so, how exactly do you go about visually syncing the carbs. Thanks in advance.
June 20th, 2011, 02:11 PM | #2 |
Doing a visual sync still will not make it perfect, invest in a sync tool or fab one up yourself for ~$10-15 and do it the correct way.
June 20th, 2011, 03:04 PM | #3 |
should have known there are no short cuts when you want to get it done right.
June 20th, 2011, 03:07 PM | #4 |
This is what we call bench syncing. Even still, it's actually easier to legitimately sync them in my opinion, as you don't have to remove the carbs to do so.
Personally, this is the tool I use to sync my carbs: http://www.powerchutes.com/manometer.asp |
Help me! (Carbs) | BlownWideOpen | 2008 - 2012 Ninja 250R Tech Talk | 38 | January 10th, 2015 09:42 PM |
Is this screw with yellow paint the one for carb syncing? | Floki | 2008 - 2012 Ninja 250R Tech Talk | 6 | January 17th, 2014 02:54 PM |
A thought experiment on carb syncing thru-out the rev range | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 15th, 2011 02:01 PM |
carb syncing | wayanlam | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 11th, 2010 12:42 AM |
No More Carbs | krbreton | The Ex-Ninjetters Lair | 12 | March 26th, 2010 08:51 AM |
