August 4th, 2011, 06:20 PM | #1 |
Join Date: Jul 2011 Motorcycle(s): 2010 Ninja 250r (RED!!!) Posts: 18
wd40 or diesel??
this has probably been gone over a million times...but what would technically be better to clean my chain with? diesel doesnt dry out the o-rings as far as i have heard. just wondering what peoples opinions are
August 4th, 2011, 06:23 PM | #2 |
I prefer WD-40. You'll be wiping it dry and lubing it up right away anyways.
August 4th, 2011, 06:39 PM | #3 |
Join Date: Dec 2010 Motorcycle(s): 2008 Ninja 250r 2009 Honda CBR600RR Posts: 178
Do NOT use WD-40. It is a penetrating solvent which can and will damage your O-rings. Use Diesel or Kerosene
August 4th, 2011, 07:01 PM | #5 |
Um Ok. I use kerosene but I've heard countless threads of people using WD-40 on their chains without a problem. If I didnt have a huge gallon of kerosene in my garage, i'd have used WD-40.
August 4th, 2011, 07:02 PM | #6 | |
i just looked it up... technically kerosene is almost the same compound as wd40...
however WBW says its probably a bad idea: http://www.webbikeworld.com/r3/motor...chain-cleaner/ more direct info: Quote:
August 4th, 2011, 07:35 PM | #7 |
Very interesting article. I will never use wd-40 again after using it to clean a chain and 200 miles later it would not move freely and several collars on the chain broke.
August 4th, 2011, 07:43 PM | #8 |
Another useful WD-40 thread ---> right here
August 4th, 2011, 09:35 PM | #9 |
Join Date: Jan 2010 Motorcycle(s): 2005 Suzuki S50, 2006 Kawasaki Ninja EX250F, 1990 Honda PC800, 2000 Yamaha TW200 Posts: 848
After you get the chain clean, lube it with Dupont Teflon Spray Lube - clean, no mess, quick to apply (spray it on), nothing (like dirt or road grime) sticks to it, highly recommended by many bike forums. You don't have to go through all that mess to clean your chain again, I use it, works great. Avail at Walmart, Ace, Loews, auto parts stores, in a blue spray can, about $8.00, a can lasts a long time. Try it, you'll like it, instead of reapplying heavy oil or chain grease.
August 4th, 2011, 09:55 PM | #10 |
Thanks for the tip Marc, sounds like some great stuff.
August 4th, 2011, 10:31 PM | #12 |
August 5th, 2011, 05:39 AM | #13 |
User Title Free Since '12
Join Date: Dec 2010 Motorcycle(s): '10 Ninja 250R Special Edition Green Posts: A lot.
MOTM - Feb '12
WD40 consists of 50% Stoddard Solvent (which is just desulferized kerosene with a lower flash point), 25% propellant, 15+% Mineral oil (light lubricating oil) 10-% Inert ingredients.
So you are basically using a solvent when you use it, very much the same as kerosene. It will attack rubber, paint finish, you name it. Including the o-rings in your chain over the long term if you leave it on you chain. But the long-term thing is the key. For short term use as a chain cleaner, it is fine. Not ideal, but fine. Better to use kerosene, but if you don't have it, WD40 works well. Though, if you use it on your chain, be sure to use it as a cleaner only, then wipe it all off and put on a good chain lube afterward. Better to use kerosene to clean the chain. I did a lengthy post here that includes the results of testing of WD40's effect on your chain and includes more detail than I'm repeating here.
"Improvement makes straight roads, but the crooked roads without improvement, are roads of genius." — William Blake |
[superbikeplanet.com] - WD40 To Sponsor Pramac Ducati MotoGP Team | Ninjette Newsbot | Motorcycling News | 0 | January 20th, 2015 07:20 AM |
I put diesel in my engine. | arnoldc6 | 1986 - 2007 Ninja 250R Tech Talk | 26 | September 6th, 2013 07:17 AM |
Mirrors + WD40 = DERP | Azhyen | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 16th, 2011 05:38 AM |
[visordown.com] - Diesel Moto Guzzi? | Ninjette Newsbot | Motorcycling News | 0 | February 7th, 2011 02:00 PM |
[motorcycledaily.com] - Diesel Motorcycles | Ninjette Newsbot | Motorcycling News | 0 | July 9th, 2008 05:56 AM |
