October 16th, 2011, 05:04 AM | #1 |
CBR? This is ninjaaaaaa!!
Pre-gen ninja and ZZR exhausts interchangeable?
Hey,
Im looking into either getting a yoshi RS3 pipe or a Two Brothers dual slip on system. I can only find on ebay systems for EX250 87-08 models. Does this mean just the ninja250 pre gen, or does it include my EX250-H? (my zzr) We both have dual exhausts and the same engines, so i assume they would fit? |
October 16th, 2011, 08:16 AM | #2 |
This link makes it appear that they would be interchangeable...
October 17th, 2011, 12:16 PM | #3 |
Join Date: Oct 2011 Motorcycle(s): 2004 Moto Guzzi V11 LeMans, 2001 ZZR250 Posts: 38
*SOMEWHAT* interchangeable. The head pipes will bolt up and the general elevation of the mounts at the rear will be correct, however the ZZR/EX250H is wider at the swingarm and rear, and the leading edge of the can (at least on the muzzy 2-1) will foul the swingarm on the right. It can be spaced outward, but leaves the end of the can sticking out on an angle that is not appealing. In addition, the lower fairing bracket (oil pan mounted one) will need to be spaced down with longer bolts, the side mounts will need to be spaced out with bits of aluminum bar stock or similar, and the fairing will not really fit all that well. A center stand stop will need to be fabricated, although the oft mentioned interference at the spring does not occur on the ZZR.
My recommendation having played a great deal with the Muzzy and now taken it off, is to get slip on pipes as opposed to a head back 2 into 1, as they will not alter the fit of the fairing up front and should not alter the attachment at the rear of the bike. While the weight savings of the Muzzy was attractive, the power gains were not particularly significant and I tired of the drone. Cheers, |
October 17th, 2011, 12:22 PM | #4 |
Great info, thx!
October 17th, 2011, 07:40 PM | #5 |
Hmm i will look into those two brother slip ons for the ex250h ninjas.
Thanks for the info on the 2into1 exhausts |
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. | AFazakerley | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 5th, 2016 02:03 PM |
Fitting a new gen front wheel on a pre gen? | thumper64 | 1986 - 2007 Ninja 250R Tech Talk | 13 | November 6th, 2013 02:44 PM |
Bike size, new gen vs pre gen(zzr) | bowerbird100 | General Motorcycling Discussion | 6 | August 1st, 2013 05:49 PM |
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames | kjohng | General Motorcycling Discussion | 5 | February 27th, 2013 10:03 AM |
FS/ part out new gen and pre gen 250r ninja | carlos | Motorcycle-related | 3 | May 14th, 2012 10:25 PM |
