November 8th, 2011, 12:01 AM | #1 |
Join Date: Sep 2011 Motorcycle(s): 2011 150cc chinaman scooter Posts: 226
$5 ebay heated grips
Just got them in...lol...3 weeks later! Install was a breeze...they get pretty warm! Opted out of using the heat shrink...just put the grips right over the heating element. The element itself has an adhesive back that sticks good enough for you to get the grips back over without moving...bring it winter!
http://www.ebay.com/itm/Motorcycle-H...item2a15458158 Edit link updated to a different seller! I have not purchased from this seller! Last futzed with by Socal5646; November 12th, 2011 at 09:36 PM. |
November 8th, 2011, 01:26 AM | #2 |
Jigglin' your Jiglets
MOTM - Apr '13
Wow, I just installed mine today. Mine were $40 and have an off lo hi switch. I just ordered this $5 one for my other bike, lets see how well they work!
November 8th, 2011, 06:09 AM | #3 |
I took the leap and ordered a set. I'm wondering if the switch is weather resistant though...
November 8th, 2011, 06:42 AM | #4 |
Join Date: May 2011 Motorcycle(s): 06 Buell Uly, 05 VStar 1100 Posts: 577
You could always buy a better switch @ autozone or somewhere couldnt you? Do these go over the grips or under them? I have a hard enough time putting grips on as it is, without having to worry about these pads, but for $5 its worth a shot. Keep is updated!
November 8th, 2011, 07:21 AM | #5 |
I used my original grips! Just used a really skinny flat head and got it all the way under the grip...then just spin it round and round (breaking up the glue underneath) until it comes off! Stick on the heating element and the grips slipped right back on 80%. A couple of whacks with a rubber mallet finished the job!
November 8th, 2011, 08:46 AM | #6 | |
November 8th, 2011, 09:03 AM | #7 |
43F this morning heading into the office.....new grips work GREAT!
November 8th, 2011, 10:26 AM | #8 | |
MOTM - Apr '13
November 12th, 2011, 08:05 PM | #9 |
Pic of grip switch installed! Thinking about getting a 3 way toggle and add a resistor For the "low" setting...maybe. Otherwise...bike got soaked a couple times this week with no I'll effects!
November 12th, 2011, 08:13 PM | #10 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
I'm guessing the title of this thread is supposed to be $55. I got a little excited when I read $5.
November 12th, 2011, 08:16 PM | #11 |
That's an interesting location for the switch. Not bad at all. Coat the electrical connections with dielectric grease if they arent weather sealed.
Do you have them tied into an existing circuit or do you have a relay? |
November 12th, 2011, 08:16 PM | #12 |
They were $5 up until just now it seems. If you go look at the seller's past auctions, its the same item for $5. The dude must've caught on
November 12th, 2011, 08:22 PM | #13 |
Wow! What a price hike!!!
November 12th, 2011, 09:24 PM | #14 |
They are hooked up to the factory accessory lead (10amp) which I added a relay to so it's only hot with the key in!
November 12th, 2011, 09:30 PM | #15 |
I'm guessing a good amount of people ordered from this thread coupled with winter coming got this guys wheels turning. Don't worry...he's in china. He's got a buddy two doors down that's gonna start whoring them out soon enough
November 12th, 2011, 09:34 PM | #16 |
Like this guy
http://www.ebay.com/itm/Motorcycle-H...item1c1f3c5da6 Or this guy http://www.ebay.com/itm/Motorcycle-H...5wt_802http:// |
November 29th, 2011, 09:04 PM | #17 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
1.5 watts for each bar doesn't sound like a whole lot of heat.
I'm not sure what mine were on the V-strom, but I think they were a bit more than that. I've got Gerbin gloves now, so don't have any need for these, but they definately look like they're worth trying for the price.
"What a sweetheart."- ninja_sleeper to me |
November 29th, 2011, 09:07 PM | #18 | |
MOTM - Apr '13
November 29th, 2011, 09:08 PM | #19 | |
Milkshake Drinker
One word of warning...relays can sometimes fail "on". Took me a while to figure out why I had a dead battery after leaving my bike parked after a rainstorm...I'd always just left switch on the high position, since it was never above freezing temps all month.
November 29th, 2011, 09:09 PM | #20 |
Milkshake Drinker
From the original ebay link at the top of this page.
I'm guessing it's a typo and it should read 3 amps? That would be 36 watts, but that would be a lot of heat for grips! IIRC, I think my gerbing gloves are only 20 or 30 watts, and that's wrapping each finger, palm, and the back of my hand.
November 29th, 2011, 09:13 PM | #21 | |
MOTM - Apr '13
Still don't see 1.5 watts though But yes that should say 12V 3A
November 29th, 2011, 09:19 PM | #22 |
Milkshake Drinker
3 watts total = 1.5 watts per handlebar.
December 5th, 2011, 08:07 AM | #23 |
Price is back down to $5.39 with free shipping.
December 5th, 2011, 09:07 AM | #24 |
Anyone know what resistor would be needed to do a high/low setup?
EDIT: Looks like this one will be it. http://www.bikesax.com/Merchant2/mer...2&Store_Code=B
09 250R SE: Paying it forward one post at a time! Don't forget to add yourself to our Member Map Last futzed with by dubojr1; December 5th, 2011 at 01:01 PM. Reason: add additional info |
December 5th, 2011, 01:00 PM | #25 | |
Milkshake Drinker
The easiest way is to do a parallel/series switch, then you don't need a resistor, but it does make the "low" setting a good bit lower than otherwise (25% of the high). It all depends on how powerful the gloves are. If we assume 25 watt gloves, 12.5 volts from the bike times the current drawn = wattage of the gloves (25w), so the current drawn must be 2. Ohms law tells us the 12.5V divided by 2 amps of current is a resistance of 6.25 ohms. For 50% power (12.5w), we want only 1 amp to pass through the gloves at 12.5 volts. With a 2.5 ohm resistor, the total circuit resistance is 8.8 ohms This draws 1.42 amps since the gloves make up 71.5% of the resistance, they dissipate 71.5% of the 17.6W total circuit power, so the gloves will run at ~12.7 watts, or half the power as without a resistor. The other 5 watts is wasted as heat in the resistor, so make sure your resistor is rated for at least 5 watts. This is a pretty inefficient way of doing things. Using a 555 chip and a power mosfet would be much more efficient. You could also just buy one of these for 23 cents, which would give simply run your gloves at 10 watts. http://www.mouser.com/ProductDetail/...xYmnKIvA6xE%3d Here's a good resistor for 44cents: http://www.mouser.com/ProductDetail/...7fG%252b3Rs%3d
December 5th, 2011, 01:09 PM | #26 | |
http://www.bikesax.com/Merchant2/mer...2&Store_Code=B Now I also know that if I change this setup to HIGH/LOW that I will also need a switch that will toggle to ON/OFF/ON and a new wiring setup. Will this setup calculations be similar to the calcs for gloves?
December 5th, 2011, 01:11 PM | #27 |
I like this switch. Small and simple. Seems a bit expensive though.
http://www.murphskits.com/catalog/pr...roducts_id=469
December 5th, 2011, 01:46 PM | #28 |
I ordered a couple sets to try, Also Murphskits is a great guy to buy from. He is the person I buy all my Connie goodies from
December 5th, 2011, 03:25 PM | #29 |
Milkshake Drinker
Grips, gloves...same principals.
December 5th, 2011, 03:29 PM | #30 |
Milkshake Drinker
December 10th, 2011, 10:58 AM | #31 |
Join Date: Apr 2010 Motorcycle(s): 2002 XR200r Posts: 128
Bought a set for my KLX250s. We'll see.
December 10th, 2011, 11:54 AM | #32 |
On my second set now...2nd set came with a broken switch...wasn't gonna wait for a switch so went to radio shack and picked one up. $3.50 for the switch! Lol. Still under 10 bucks!
December 31st, 2011, 10:57 AM | #33 |
I just installed the left side and temporarily hooked them up on my KLX250 they work! Did you guys use Huge heat shrink tubing? I don't get what that is for. I just wrapped the bars with some electrical tape, put the sticky stuff on the heaters and wrapped them on the bars. I didn't do the throttle side yet, since I'm out of WD40 to get the grip off the throttle tube.
So far...so good. that switch bracket fits perfectly on the bolt that the clutch lever pivots on. I didn't want to do a permanent mount on these cheapies. |
December 31st, 2011, 12:07 PM | #34 | |
January 13th, 2012, 09:41 AM | #35 |
Join Date: Jun 2011 Motorcycle(s): 2002 ninja 250 Posts: 96
January 13th, 2012, 05:10 PM | #36 |
I believe it is for insulation on the clutch bars so that heat doesnt so readily get dissipated into the metal bars. I used electrical tape when I installed mine and then I wrapped it in aluminum tape to help spread the heat and secure the grips onto the bars.
2009 Ninja 250R SE Green Sport Touring Style: ZG ST; Symtec heated grips; RAM GPS w/ mUSB; DIY reshaped seat; DIY Givi E21 Sidecases; 15T sprocket |
January 13th, 2012, 05:14 PM | #37 |
I still don't understand where it goes. are you saying it goes on the break and clutch levers to keep from heating up? what are clutch bars? you put aluminum tape over or under the grips?
January 13th, 2012, 08:12 PM | #38 |
I believe it goes on your bars BEFORE you put the heating strip on. That way the heat is more likely to travel through the grip, rather than being absorbed by the metal bar.
January 14th, 2012, 12:14 AM | #39 | ||
The aluminum tape is over the heating elements and under the grips. If you do decide to wrap aluminum tape, wrap it in the direction you'll be twisting the throttle or else it might unravel over time.
March 17th, 2012, 06:06 PM | #40 |
Join Date: May 2011 Motorcycle(s): 2006 GSXR 750; 1983 CB750SC Posts: 277
I just got these and I'm kind of confused. I've taken off both grips and I assume you put the shrink tube on first to insulate from the bars, then peel the heat pads to expose the sticky backing and stick them on? Once these pads are on, do I use the tape provided to cover them? If not, will they melt the grips when I put them back on?
Or do I use the tape provided (which looks more like electrical tape than aluminum tape..) to wrap the bare bars first, then stick the heat pads on, then put the shrink tubing over that, before putting the grips back on? =[ |
DIY - Hot Grips Heated Grips Install | NathanF | 2008 - 2012 Ninja 250R Farkles | 26 | January 23rd, 2014 03:37 PM |
Anyone using heated grips? | caineroad | General Motorcycling Discussion | 5 | September 24th, 2013 06:05 AM |
tried these heated grips? | smackenz | 2008 - 2012 Ninja 250R Farkles | 7 | October 17th, 2012 03:11 PM |
heated grips | bhalv | 1986 - 2007 Ninja 250R Farkles | 10 | January 17th, 2011 09:39 PM |
Heated Grips | sudadoda | 2008 - 2012 Ninja 250R Farkles | 7 | May 4th, 2010 07:15 AM |
